C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Fuel system
Old Feb 28, 2020 | 10:27 PM
Will_L's Avatar
Will_L
Default Fuel system
Is the stock fuel system adequate for a
09 ls3 c6
headers exhaust cam and 100 shot either wet or dry
Old Mar 1, 2020 | 07:34 PM
~STOLEN~'s Avatar
~STOLEN~
I ran 65 lb Injectors and a 100 shot (wet) for over a year with zero problems.
Old Mar 1, 2020 | 07:45 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
I guess it depends on how much HP the car is making with the 100 shot activated.
The LS3 uses the same injectors as the 505 Net HP LS7 engine (42 Lb/Hr @ 58 PSI)
A dyno pull with a wide band could tell you if it is leaning out any when the 100 shot is activated at WOT.
Old Mar 1, 2020 | 08:31 PM
Will_L's Avatar
Will_L
Thanks guys
ya was just wondering the capabilities of the factory fuel system
Old Mar 1, 2020 | 08:50 PM
Turbo6TA's Avatar
Turbo6TA
If you don't want to spend big bucks on injectors, just get a set of OEM LS9 injectors (they are 52 Lb / Hr @ 58 PSI)
It's the next step up from your stock LS3 injectors.
However, when you make an injector change, you most definitely need to get the car dyno tuned to run on the new injectors ... If not, it will run like crap.
Old Mar 1, 2020 | 08:54 PM
CI GS's Avatar
CI GS
You’re going to be very close or at the limit of your fuel system with a cam and nitrous, even with just a 100 hp shot, and the injectors will probably be at or beyond their limit with a 100 hp dry shot. If it’s wet, it doesn’t matter what injectors you’re running.
You might get away with it with a small cam, but it’s not worth it to risk grenading your motor, IMV.
The cheapest solution would be to get a Racetronix fuel pump harness with the aux fuel pump booster connector kit and a BAP and wire the BAP to switch on when you arm or activate the nitrous.
Old Mar 1, 2020 | 09:05 PM
Turbo6TA's Avatar
Turbo6TA
Sammy ... Are you still over there in Jolly ol' England ?
If so, say 'Hi' to the queen for me
Old Mar 1, 2020 | 09:31 PM
Will_L's Avatar
Will_L
I hear ya
guess if I do I’ll go wet with a standalone
where in FL are you turbo6ta
Old Mar 1, 2020 | 09:55 PM
Turbo6TA's Avatar
Turbo6TA
Cape Coral ...
Old Mar 2, 2020 | 02:29 AM
CI GS's Avatar
CI GS
lol. Nope. I never go there, except in transit to fly somewhere else. Right now I’m in Portugal, hence the time difference.
Old Mar 2, 2020 | 02:32 AM
CI GS's Avatar
CI GS
Originally Posted by Will_L
I hear ya
Yep, that’s also a good option, and an easier install, albeit not as cheap as buying a BAP and a FP harness. And you could also go 200hp+ then too.
Old Mar 2, 2020 | 05:08 AM
Turbo6TA's Avatar
Turbo6TA
For some reason I had it in my mind that you were going to England ... Now I remember, you did mention Portugal.
I am back from Costa Rica ... I was there for only 5 days
Old Mar 2, 2020 | 05:49 AM
Will_L's Avatar
Will_L
Who does your tuning over there
in on the east coast near stuart
Old Mar 2, 2020 | 07:00 AM
Turbo6TA's Avatar
Turbo6TA
I drive over to Pompano Beach (just north of Fort Lauderdale) and have Howard Tanner at Redline Motorsports do the dyno tuning .... Excellent shop that specializes in later model GM
https://www.redline-motorsports.net/
Old Mar 2, 2020 | 08:56 AM
Redline Motorsports's Avatar
Redline Motorsports
Hey Will,
Please let us know if we can be of assistance with your new power goals. Not your too far off in fueling requirements for what you need.
Thanks HT
Old Mar 2, 2020 | 09:33 AM
Will_L's Avatar
Will_L
Hey howard
its will
you guys are tuning the car in two weeks after i get the cam and exhaust on in two weeks😁
ill have some nitrous and head questions
Old Mar 2, 2020 | 04:12 PM
CI GS's Avatar
CI GS
Hey howard
its will
Looks like you’re in good hands. Let us know how it turns out.
To Fuel system
