EForce LS2 Dyno HP
Kooks 1⁷/⁸ headers, 3" h pipe no cats and Borla ATAK. Like this its loud as hell.
The E Force is the base kit with 3.85" pulley, stock fuel pump. Also has a Mighty Mouse catch can. Very basic stuff.
At the tune it made 5.5 psi boost, 440 max WHP at 5700 rpm and 449 max tq at 4550 rpm. It was at 435 tq at 3700 rpm. It was 55 degrees outside.
These LS2 cars make about 355 whp in factory trim.
The car seemed to feel faster with the E Force, stock cats and H pipe with Borla ATAK mufflers.
Thats all she wrote.
Another excellent upgrade that is relatively cheap is the Racetronix Fuelpump Hotwire. It sends voltage directly from the alternator to the fuel pump. It will usually add about a volt more to power the pump which will increase its flow. This is actually a good upgrade for any Vette.
It was dyno tuned but I dont think they were exp with it. The tailpipes have black on them and from 20 mph it doesnt feel as strong.
The wide band goes to 12 -12.5 under boost. At 40 mph it swings between 14 - 10 or 14 - 12.
Same shop put headers on it but theres a leak at this ball socket. Looks like they tightened one side all the way before starting the other side. Probly should have tightened it more evenly.
What dyu think?
What dyu think?
Hard to tell but it looks a bit off. Should be easy for you to correct.
As for the belt, you shouldn’t need a new belt but if you do, you should be able to get the belt you need if you have an Oreilly’s near by. You can find Gates belts in 1/2 inch increment sizes. For example, my car was using a K061030 belt which is 103.0 inches. I needed 1/2 shorter so got the K06102.5 (102.5). You can get 3 or even 4 belts in different sizes and see which one fits best and return the others.
As for tuners, some not good, some are okay, and some are great. I had my car tuned after adding my E-force and he did okay but I ending up going to a second tuner and he really dialed in the tune.
As for your AFR, for boosted, you should be closer to 11.
For the exhaust leak,
this morning i took the car back to the shop. They found one of the O2 bung plugs fell out. Once the plug was installed no more leak.
They also showed me the max injector duty cycle was at 75.4%. These injectors are part of the E Force kit. 52 pounders i believe.
Question:
To change pullys the throttle body has to be moved.
Can i just remove the 4 bolts that retain the t body and push it out of the way enuff to access the pulley bolts?
Question:
I felt power was down so I took my car to a far more experienced shop here in the Chicago area called Speed Inc. No changes were made to the combo as indicated in the 1st post other than adding a Kenne Bell BAP.
They did a dyno tune including trans tune, its an A6.
On 5 psi boost it made 481 whp and 480tq by 3600 with a max of 484 tq. Most notable was how much better the trans worked while moving in and out of traffic on the interstate.
They also did an oil change and trans service.
Thats all for this one. Next year I want to trade for a C6 Grand Sport manual or C7 Stingray A8 or manual.
