C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
upgrade Callaway
Old Apr 23, 2020 | 03:48 PM
jorgez28's Avatar
jorgez28
Default upgrade Callaway
Hi everyone I would like to up grade the boost on my stock Callaway what is the best way to upgrade boost and is still safe level?
Old Apr 23, 2020 | 08:58 PM
old motorhead's Avatar
old motorhead
What engine do you have? What blower do you have? What drive ratio (pulley sizes) do you have? Do you have long tube headers?
Old Apr 24, 2020 | 09:42 AM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
The safest would be long tube headers and a slightly smaller pulley to get the boost back to 7.5-8.5 lbs. You will need a tune with that.
Old Apr 24, 2020 | 05:50 PM
jorgez28's Avatar
jorgez28
Thanks for the replies. I have an LS2 with the stock blower that Callaway uses I believe its a TVS 2300 but not curtain. the pully should be the one that came with the kit.
Old Apr 24, 2020 | 07:31 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
The LS2 got the 2000cc supercharger with 3 lobe rotors, not the 4 lobe TVS. I’m pretty sure, Stock was 7.5 lbs of boost.
Old Apr 24, 2020 | 07:36 PM
Chiselchst's Avatar
Chiselchst
What are your RWHP goals? There isn't a definitive "safe" level really, a lot depends on the tuner, octane, maintenance, etc. Once we start messing with these engines, we take a risk....
Old Apr 24, 2020 | 10:19 PM
old motorhead
MP122? At mild boost, a really good blower. I had one on a 6L LQ4. Thousands of trouble free miles. When the HP junkies found out that they (no matter how smart they thought they were) couldn't make the MP122 achieve 800 hp, the masterminds deemed it a terrible blower. Really smart guys there.
Old Apr 25, 2020 | 12:23 AM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
They used the MP122, it was rebranded SC2000 at some point.
Old Apr 25, 2020 | 02:24 PM
jorgez28's Avatar
jorgez28
I would like stock zr1 level power so 638 hp would be great I have a Callaway 560 so I’m looking at 80 hp gain
Old Apr 25, 2020 | 03:38 PM
old motorhead
Add a smaller pulley by 3 or 4 tenths of an inch. Add long tube headers and a good flowing cat back. You may need additional octane too. Flex fuel running E85 would make it much easier. Upgrading your camshaft would make it easier too.
Old Apr 25, 2020 | 05:48 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
SC560 should have MP112 vs MP122, if I recall. Early cars in 2006 got that unit installed, prior to the MP122/CS2000 unit which was for the 2008+ LS3 Cars
Old Apr 25, 2020 | 05:55 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
fuzzy memory...thanks.
Old Apr 26, 2020 | 11:50 AM
old motorhead
I haven't played with an MP112 in 15 or so years. Magnuson had a program where you could return your MP112 blower assembly to them and they would return it with an MP122 in place of the 112. I did just that in 2006 or 2007. I do remember that, at some point, spinning the MP112 faster doesn't do much other than make overly high IAT temps. You can certainly spin your blower faster than what Callaway has spinning it for a stock LS2. Maybe go down a couple of pulley sizes and add long tube headers. A blower cam would reduce boost levels and run cooler also. A higher volume coolant pump and a more efficient heat exchanger would help too.
I don't know what you have for injectors and a fuel system. If you have to upgrade the fuel pump and injectors, there won't be a better time to invest in a flex fuel system. With E85, hitting your power goals will be much easier.
Old Apr 28, 2020 | 02:25 PM
sonnysucks's Avatar
sonnysucks
I would flex fuel, you can pick up almost half your goal tuning for e85... fueling and injectors aren't cheap though.
Old May 20, 2020 | 07:31 PM
jorgez28's Avatar
jorgez28
Thanks guys how can I tell if I have an MP112 or MP122?
Old May 20, 2020 | 07:38 PM
old motorhead
Seems like the MP122 had an extra rib or two. It was same width only a longer blower case. That might come up on a google search.
Old May 20, 2020 | 07:54 PM
*89x2*'s Avatar
*89x2*
You could always call Callaway and ask them... They keep records
Old May 23, 2020 | 10:45 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
To upgrade Callaway
