C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
E85 conversion
Old Jun 7, 2020 | 03:18 PM
Jprc2015's Avatar
Jprc2015
Default E85 conversion
I recently bought a 05 vette Ls2 with an A&a supercharger it has a boost a pump ...Looking to do a e85 conversion. What setup do you guys recommend?
Old Jun 7, 2020 | 08:34 PM
CI GS's Avatar
CI GS
You’re asking about which Flex fuel kit to get?
Or are you asking whether your fuel system will be up to the task?
The best FF kit is the DSX kit, which is simple plug and play, although I’m not so sure about on the 2005 cars. Best guy to ask is schpenxel. He’s a guru on that kind of stuff, having ripped his 2005 C6 apart and put it back together like 500,000 times.
If you’re asking what to do with the fuel system, I would say chuck the BAP and do an ECS Stage 1 fuel system and hope that the stock pump doesn’t crap the bed from methanol use. That’s what I did, but I’m sure there’s going to be alternate opinions on that.
And, btw, you need to make sure that you have enough injector for E85 as well, since you’re going to be using about 30% more fuel.
Old Jun 7, 2020 | 09:08 PM
Jprc2015's Avatar
Jprc2015
all of the above ...the kit I have been looking at the Dsx kit instead of piecing it together but also what injectors to run
Old Jun 14, 2020 | 11:25 AM
scottg's Avatar
scottg
Will let you know how mine did. Going in this week to have Flex-fuel conversion and A&A dual external pump. I know the tuner will be putting in 1000 pound injectors. At 65 lbs now. and at 95% duty. I Have a Heartbeat blower in it now.
Old Jun 14, 2020 | 10:09 PM
CI GS's Avatar
CI GS
Meant to respond to this from the other day, but forgot to. My recommendation would be to go with the ID1050Xs or 1300Xs, if you’re at the power level to need that big an injector. ID has a very good injector size calculator on their website:
https://injectordynamics.com/injector-selector/
The 1300Xs are like $800 more than the 1050s, so you’d want to figure out what size you need.
ID injectors are pricey, but were reportedly designed specifically to be used with Ethanol, which can cause internal corrosion in an inferior injector, which could cost you an engine if an injector fails at high rpm.
Old Jun 14, 2020 | 10:23 PM
sonnysucks's Avatar
sonnysucks
I have the fore triple and ID1300's. remove boost a pump and beast it.
To E85 conversion
