C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
intercooler options
Old Jun 15, 2020 | 02:43 PM
mikeC62008's Avatar
mikeC62008
Default intercooler options
Has anyone used A&A intercooler with ECS kit? It bigger than standard one from ECS. Besides Procharger one is there any other options for intercooler
Old Jun 15, 2020 | 02:53 PM
skydaman's Avatar
skydaman
Treadstone intercoolers work well for the price and fit up front fairly easily. I notched the cross rail and used the TR1245, but you could use the TR1045 if you don't feel like notching it.
Old Jun 16, 2020 | 12:44 PM
Unreal's Avatar
Unreal
Bigger doesnt mean better.
ECS has an optional larger core.
If you are going through hassle, do a nice custom setup or the ECS big core. That being said, made 1100rwhp with ease on base ECS FMIC, so what are you trying to do? When I upgraded all it did was cause more overheating/heat issues for the radiator.
Old Jun 16, 2020 | 12:46 PM
mikeC62008's Avatar
mikeC62008
Ok. if smaller ECS cooler is fine then I'll roll with that. Thanks for the replies
Old Jun 16, 2020 | 12:47 PM
Unreal's Avatar
Unreal
If you are going for 1200+hp, sure it can use an upgrade, and when you get into 900+ you can see gains, but for most people they are not there. Plus the smaller IC allows more air to the radiator and car so it doesn't overheat as easy.
Plus tube/fin vs bar/plate, vs fin density/etc etc. Size is such a small part of a FMIC efficiency.
Old Jun 16, 2020 | 01:26 PM
skydaman's Avatar
skydaman
True smaller Garrett cores often outperform larger units, but they come at a higher price. I often see people make decent power on single gear dyno pulls on smaller intercoolers, but on back to back passes the IAT's start to rise rapidly.
Old Jun 16, 2020 | 01:30 PM
Unreal's Avatar
Unreal
Yep, garret or bell cores are not cheap, but work great compared to cheap china stuff. My core alone was like 40lbs from Bell. Just from a heat sink standpoint, it is a ton of aluminum.
Old Jun 16, 2020 | 08:10 PM
droptopsnake01's Avatar
droptopsnake01
Check out Shearer Fabrication.
Old Jun 17, 2020 | 11:44 AM
skydaman's Avatar
skydaman
I had some of his stuff, most of it doesn't package well in the typical vette engine bay but it looks nice. Wasn't terribly impressed by the $1,500+ intercooler when it barely out performed the $400-500 range intercoolers. Money can certainly be spent elsewhere, especially on E85 that isn't as picky about IAT's as pump gas. But for race cars and those without a tight budget he makes some nice stuff.
Old Jun 17, 2020 | 01:35 PM
Unreal's Avatar
Unreal
I've known Ron for a long time. Great stuff, and great products but once again, unless you are going for huge numbers, his stuff would be overkill.
Old Jun 17, 2020 | 04:55 PM
WestCyril's Avatar
WestCyril
Better core will always be beneficial regardless of power levels, but like unreal has mentioned until you're pushing 900+ one of the standard or even china cores will be fine.
.Setup also can impact IAT issues. If you have a small blower or small turbo and start spinning them hard they start to pump hot air a lot quicker.
Old Jun 17, 2020 | 08:42 PM
skydaman's Avatar
skydaman
My results were from a 1100+ 8 second street car. You are correct because I ran the turbos without an intercooler first and the larger 94mm had lower IAT’s then a 80mm. But the 94mm also makes more without an intercooler then most people do with one.
Currently I run two 1000hp china A2W cores and on a 30psi quarter mile pass I get 5-7 degree rise, on shearers 1800hp hi ram intercooler I got a 10-15 degree rise. So its a $150 vs $1600 decision people have to make. The shearer did do a bit better than the china air to air cores not by a huge amount.
Old Jun 17, 2020 | 10:25 PM
jayyyw's Avatar
jayyyw
I have $800 into my custom Garrett core intercooler. 24x10x4.5 is the core size. Been proven to over 1600whp, 30 degree temp rise with less than 1psi loss through the core.
Old Jun 18, 2020 | 07:23 AM
skydaman's Avatar
skydaman
$800 is a good price point for a complete garrett. You should have less temp rise with some ice, on a ~75-80 degree day we didn't see over 95 degree IAT with shearers unit.
Most all the air to water cores have less pressure drop then the air to airs, some of the china air to airs have pretty bad pressure loss.
Old Jun 18, 2020 | 11:14 AM
Detoxx03's Avatar
Detoxx03
I ran the ProCharger race IC and it did great. For my new setup is from No Corners Cut and it uses a Bell core. I paid $1500 for it but if I was staying with the old setup the PC worked fine.
Old Jun 18, 2020 | 08:08 PM
jayyyw's Avatar
jayyyw
Mine is setup air 2 air
Old Jun 19, 2020 | 05:12 AM
chuntington101's Avatar
chuntington101
thats a lot more power than what Garrett say their core will support. Isn’t the 24x12x4.5 only rated to 950bhp? You have 2inch chopped off that as well.
To intercooler options
Old Jun 19, 2020 | 05:14 AM
chuntington101
Any pics of the setup? Always like seeing air to water option on corvettes as not many people are going that way.
Old Jun 19, 2020 | 05:33 AM
jayyyw's Avatar
jayyyw
It's 2 cores welded together. 12x10x4.5. The guy that built my end tanks for it runs the same cores on his 1600+whp truck.
Old Jun 19, 2020 | 08:05 AM
skydaman's Avatar
skydaman
I run a Rhodes combo IC/fuel tank and two of these hidden under the dash in place of the heater core:
