Edelbrock e force
You don't need to replace the fuel pump but you could upgrade to a Z06 pump if you wanted to do the work. It is much easier to just install a Boost-A-Pump.
The other thing you will need is the 3.5" pulley which you can get from Summit Racing. I think it is $50.
If you are using the stock Edelbrock tune, then you are good as the tune for both the Stage 1 and Stage 2 is the same.
I would highly recommend though that you get a dyno tune as the Edelbrock tune is very rich for safety and leaves a good bit of power on the table.
If you already have a dyno tune, then you would just need a minor retune.
