C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
C6 Corvette Engine ground
Old Aug 25, 2020 | 04:24 PM
Itneverendz's Avatar
Itneverendz
4th Gear
Default C6 Corvette Engine ground
How is the engine grounded in these cars? Besides the ground cable that is connect to the starter, are there any other wires connecting the battery to engine (block or cylinder head), or engine to frame?
can a bad engine ground cause a random misfire/stumble?
Old Aug 26, 2020 | 02:03 AM
REL3's Avatar
REL3
I dont know where all the grounding areas are for the car but I would run down burnt/loose wires, clogged injectors, and old spark plugs for this issue you are describing first. If you have already done that then check for vacuum leaks and malfunctioning sensors.
There are some really good and cheap OSBII port readers that will bluetooth right to your phone and tell you what the computer is saying in regards to codes.
Hope this helps.
Old Aug 26, 2020 | 03:22 AM
Itneverendz
4th Gear
Hope this helps.
the car has an aftermarket ECU. The OBD is not utilized. We have checked and replaced all plugs, wires, coils. Its a new build and has all new parts as well. There is no vacuum leak
Im trying to understand how the engine is grounded from the factory with the factory engine harness.
Old Aug 26, 2020 | 08:13 AM
Spaceme1117's Avatar
Spaceme1117
If I am remembering correctly there is a ground on each side of the engine toward the front closer to the air filters. They are studs that stick up from the frame on each side.
I think there is also another ground on each side also on the frame closer to the back of the engine. I think one is kind of under the brake fluid reservior and the other in a similar location on the passenger side.
Not sure of other grounds.
Old Aug 26, 2020 | 01:04 PM
playtoy's Avatar
playtoy
on my car which is a 2005 there is a ground located next to each motor mount and either one or two on the back of the heads
Old Aug 26, 2020 | 01:08 PM
Pb82 Ronin's Avatar
Pb82 Ronin
You're welcome.
https://www.corvetteforum.com/forums...post1564664336
Old Aug 26, 2020 | 01:15 PM
MysteryMob's Avatar
MysteryMob
Yes, improper ground can cause a misfire. Happened on my GTO after installing heads, my friend did not tighten one and it was misfiring under load. It was immediately solved after tightening it.
To C6 Corvette Engine ground
