It’s significantly heavier than the aluminum block when you add a 60lb turbo and large A/A innercooler. I had to go to coil overs to get the nose out of the weeds.
Pros: Ability to run 6-bolt heads, can handle 2000+ hp, better oiling, thicker walls between bores
Cons: Weight (110lbs heavier), heat retention
It really comes down to your power goals and current block in your car. I pulled an LS7 out of my car and put in a Dart SHP since I was looking to make more power than a typical LS7 can handle, plus I plan to run 6-bolt heads. If you have an LS3, I would just upgrade internals since those have proven to hold a ton of power. Aftermarket aluminum blocks are pretty pricey if you go that route.
Probably pushing it on the pistons but not remotely unheard of.
I usually stop at 800rwtq when tuning stock LS3 motors personally. There are certainly plenty that have held more... but I think the pistons get a little iffy above there. Running E85 obviously is pretty much required unless you're dumping in a ton of meth or race fuel or something, and even that much meth can have issues with being evenly distributed at that point.
