They barely hold vacuum without a lot of care, let alone boost. Wouldn't even consider it. Waste of money and high risk.
I totally agree
These intakes make power, but they can't even hold a seal without boost.
I've torqued mine 4 times and still have a leak somwhere, the bolts are always loose.
pretty sad for a $1k intake.
I’ve had zero issues with mine. People keep saying the bolts don’t stay tight but how many of those actually READ the instructions. Torque is supposed to be done in 2 stages. I started 40inlbs then the 75 it calls for. After final tq I did a final pass to make sure they were at correct tq. I used blue locktite also. I’ve checked the bolts along with other things I check on a weekly basis. None have came loose.
I followed the directions to a T.
I did not put blue loctite on mine.
I totally agree
