C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Main studs
Old Sep 17, 2020 | 07:06 AM
SteveJewels's Avatar
SteveJewels
Default Main studs
2010 base, LS3
Can the main bolts be replaced with studs without pulling the engine?
Old Sep 17, 2020 | 09:58 AM
da6speed's Avatar
da6speed
The proper procedure is to have a line hone/bore done when going to studs.
Old Sep 17, 2020 | 10:00 AM
Pb82 Ronin's Avatar
Pb82 Ronin
This. Can you? Yes. Should you? Not if you want your engine to last more than a few hours.
Old Sep 17, 2020 | 06:59 PM
SteveJewels
So it would seem.
Thanks!
I found this Googling changing main bolts "This is a quote from ARP (When changing from factory fasteners to high strenth fasteners, clamping force and tolerances WILL change. The main bores should be align honed using the fasteners which will be installed at the recommended preload)
Any blocks or engines we build that come through our shop we ALWAYS line hone them and replace the stock hardware to ARP and we have never had any problems using this procedure."
It was old but I can't see why it would have changed.
Old Sep 17, 2020 | 11:42 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Aluminum blocks and bearing caps distort like crazy, more tension/pressure = more bendy. Is it enough to matter? No clue. Maybe if you could torque them the same as stock they’d be fine. Main bolts don’t really seem to be a weakness on these motors though, do they?
To Main studs
