C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
ECS stage 1 e85 install help please.
Old Sep 20, 2020 | 05:17 PM
m60gov20's Avatar
m60gov20
Default ECS stage 1 e85 install help please.
I’m finally getting my fuel system installed and have a fee question.
Should there be an Oring between these two fittings?
Should this be a 90 or a 45. It looks like it should be a 45 and the directions say it should be?
Does everything look correct?
Old Sep 20, 2020 | 11:53 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
ECS instructions strike again
Old Sep 21, 2020 | 10:40 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Different fittings for different pumps so the lines fit better, call in is easiest, 609-752-0321, we are happy to help.
Old Sep 21, 2020 | 01:46 PM
Unreal's Avatar
Unreal
Anything with a tapered seal won't use an oring. You can see that fitting has a taper seal, so no oring would be used.
Old Sep 22, 2020 | 08:52 PM
m60gov20's Avatar
m60gov20
You probably can't tell but the tapered fitting on the pump doesn't bottom out inside the check valve. I didn't look in the package with the mounting screws for the fuel pump and there was an oring the correct diameter.
Old Sep 23, 2020 | 09:41 AM
Gotit4cheap16's Avatar
Gotit4cheap16
Had no problems installing mine and putting it all together. No leaks either.
Old Sep 23, 2020 | 12:06 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Good to hear!
Old Sep 23, 2020 | 12:16 PM
m60gov20's Avatar
m60gov20
Are you sure the check valve is in the correct location? See the flow direction arrow? I’d move the pump up a little higher so the line is protected by the frame. [img]blob:https://www.corvetteforum.com/2fe01974-4035-4c1e-8ed6-397bf8228903[/img]
Old Sep 23, 2020 | 12:18 PM
m60gov20's Avatar
m60gov20
Old Sep 28, 2020 | 12:18 PM
Gotit4cheap16
yea it is. I did major research before i installed mine especially on here. Take as look at this post that i commented on earlier in the year as well. You will see others with their install pics as well and our install are all similar in how its put together. Making 805rwhp at 60% duty cycle with 1300 fic injectors on stock fuel pump on e50.
https://www.corvetteforum.com/forums...ll-pics-2.html
To ECS stage 1 e85 install help please.
