C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Meth injection sprayer loose
Old Nov 21, 2020 | 07:27 PM
ubknls's Avatar
ubknls
Default Meth injection sprayer loose
I just noticed that 1 of the meth injectors on the air intake pipe is a little loose. Should I be concerned? Any info would be great
Old Nov 21, 2020 | 09:31 PM
TTZ06VETTE's Avatar
TTZ06VETTE
Is it the nozzle thats loose or the line? Is it going into a soft coupler or a hard pipe. If its the nozzle it could be a problem...
Old Nov 21, 2020 | 09:35 PM
ubknls's Avatar
ubknls
Nozzle that goes into the intake pipe
File Type: mov
Old Nov 22, 2020 | 12:27 AM
TTZ06VETTE's Avatar
TTZ06VETTE
I think your OK. Should be a rubber or urethane grommet on inside.
Old Nov 22, 2020 | 07:27 PM
playtoy's Avatar
playtoy
You need to make sure the nozzle is not backing out. If it does your going to suck it down into your motor, if your in boost when it come off your going to burn your car to the ground. Be on the safe side and remove the charge tube and make sure the nozzle is tight and not backing off.
Old Nov 23, 2020 | 11:44 AM
sonnysucks's Avatar
sonnysucks
^ I kinda agree... unless the other nozzle (assume you have dual+?) is the same way... I would likey check. Mine is solid tight pipe threaded into the intake pipe.
Old Nov 23, 2020 | 09:58 PM
73DBG's Avatar
73DBG
You should 100% pull the charge pipe tighten and check the thread seal, make sure it’s good to go. I had this happen a few weeks ago, wasn’t in danger of coming off and going into the engine but you never want loose or leaking meth connectors. It’s a pretty simple easy job man.
To Meth injection sprayer loose
