C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Injector sizing please
Old Nov 26, 2020 | 09:25 AM
SteveJewels's Avatar
SteveJewels
Default Injector sizing please
I am convinced that E85 is the way to go. I turned over the furniture, looked under the sofa cushions and car seat, smashed the piggy bank and I think I have put together enough spare change to convert to dual fuel so I can burn corn squeezins.
2010, 6.2l LS3, 4L65/70e, V-2 Ti+, cam, springs, rockers, BAP, headers, M1, 3" exhaust.
Assuming the fueling system is adequately sized and properly configured, how much WHP will ID1050X's support on E85?
Thanks!
Old Nov 26, 2020 | 02:05 PM
WestCyril's Avatar
WestCyril
ID1050x should support 800ish on E85 pretty easily.
Old Nov 29, 2020 | 06:44 PM
Creamo3's Avatar
Creamo3
FIC has different calculators as well that are helpful: https://fuelinjectorclinic.com/faqs/
1050's should be good up to 900whp on E85 assuming you have enough pump behind them, if you're spraying meth you'll have a little more headroom as well.
Old Nov 29, 2020 | 07:21 PM
SteveJewels
Thank you @Creamo3
That is what I have been coming up with as well.
I have a base with the factory (as far as I know) pump and a BAP. I have been looking at external pumps. Not to keen on punching a hole in the gas tank but it looks to be doable. Not real keen on dropping the tank either. Guess I'll have to pick my poison.
Old Nov 30, 2020 | 09:54 AM
Creamo3's Avatar
Creamo3
Originally Posted by SteveJewels
Thank you @Creamo3
I'm running an external pump setup, but eventually upgraded the in-tank pump as well since you'll need to drop the tanks to install regulator block-off plugs if you want to run a boost/vacuum referenced regulator.
Plugs: https://www.racetronix.biz/p/regulat...-r/reg-block02 https://www.racetronix.biz/p/regulat...-r/reg-block02
Old Dec 1, 2020 | 07:50 PM
SteveJewels
@Creamo3 Thank you sir. I have so much to learn. I was wondering how to convert to a returnless and make it boost\vacuum referenced.
To Injector sizing please
