C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
The ultimate trans/ diff package. Billet sequential with quick change rear end
Old Dec 10, 2020 | 02:31 PM
BLOWNBLUEZ06@RKT Performance's Avatar
Supporting Vendor
Default The ultimate trans/ diff package. Billet sequential with quick change rear end
Over the past 2 years, I’ve worked with Rick and Clay at RTS to come up with the most powerful solution for our Corvettes. It fits both C5 and C6’s I've got a complete billet sequential system that’s a complete, bolt-in solution for those that don’t want to keep throwing money at their transmission and don’t care to play with the automatics. They each have a Billet case, 300m and 9310 shafts and gears throughout, billet pump with integrated spray bar system. There is also an isolated section of the transmission which holds a pair of gears that can be swapped in 20 minutes on the bench and allow you to multiply or divide the ratios of the entire transmission by a factor. Since this is a racing transmission, the gear ratios from gear to gear remain relatively close. There is no such thing as a .65 6th gear ratio however there are many gear options for each gear. Although there isn’t a low 6th gear option, overdrive is an option and you can top out 6th gear at any power level. The differential is a RTS 1000. The main housing is a quick change from Winters, which incorporates 10” ring and pinion combination. With the quick-change differential, you gain the ability to have almost countless ratio options. The gears can be changed easily, literally in minutes. Here's an example of how it benefits you: Imagine for a moment that you want to have your car top out 6th gear in the 1/8mi this weekend and the following weekend, you have a 1/2mi race. You would remove 6 cap screws, change one pair of gears (they cost around 88.00/pair) and you're ready to go. This has the best of the best of everything. Will hold anything you can throw at it. So far it's held up to many high powered cars including a number of Dodge Vipers, some abusive, high-powered Formula Pro Drift series cars, making well north of 1kwhp (and they aren't always spinning). It's also held up on a promod making thousands to the tire. This kit is complete from end to end with a 10" quick change differential, custom DSS Level 5 Race axle shafts, custom torque tube with custom DSS shaft, shifter and many options, including bluetooth paddle shifting, automatic shifting after launch, rev matching on down shifts, torque (fuel/spark) cut on the upshifts and more. It’s not cheap but it’s important to consider not only what's included, but what it’s capable of. There is currently no product on this planet that even comes remotely close to doing what this 6XD package will do or holding the kinds of power that this has already held up to. When all things are taken into consideration, it's an incredible price. For those of you that don't want to give up the interaction with your car that a manual transmission offers, don't want to worry about making 1k 2k even 3kwhp and having your transmission and differential break regularly, this will be the only real, viable option for a street car.The base package costs just under 30 and is going up by 1100.00 in January.
I might be interested in buying your old transmission and differential for added convenience.I'll be adding more pictures as I am able. Please do not call the shop. PM me directly for help with this package and if needed I'll set up a time for a phone call where we can discuss things at length.
This is the integrated oil pump for spraying the gears directly. The spray bar is machined into the case.
The billet shifter is offset to allow the driver to set the shifter in the most comfortable position. They are offered with different offsets, up to 4", creating an 8" allowable variance from side to side or front to year. That is actually larger than the hole in the tunnel will accept for our Vettes though. a 2" offset will be more than enough.
Notice the differential is supported at both the front and rear, by the front and rear of the factory cradle. The billet mounting brackets in the rear are easily installed in minutes.
billet rear cover for the quick change differential.
behind the support rail, lies a load cell. The placement and quality of this load cell means that you won't end up having to have some 2' long shifter in order for it to work.
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
Old Dec 13, 2020 | 08:24 AM
Supporting Vendor
More Info:
Originally Posted by Pb82 Ronin
Wait...what? Torsen? As in Torsen diff??? I never saw Torsen mentioned...OP can we get a Torsen diff in these?
All they use is Torsen along with 300m shafts etc. They've never broken one of these differentials before and they've been put through hell so far. I plan to beat the crap out of mine and will get videos once I do.
The top chart is the differential gear chart for each pair of gears. (85.00 per pair) The bottom chart is based on one of my gear sets for playing at the 1/4mi track.
Old Dec 18, 2020 | 04:31 AM
Rkreigh's Avatar
Rkreigh
Originally Posted by BLOWNBLUEZ06@RKT Performance
More Info:
do a frankenstein mod and put this in c8 and the world is your oyster. So many c8 guys would climb over each other to get a tranny like this.
I think a streetable c8r would be pretty cool if I could muster it. On the "low end" of the gene pool we're buying up old nascar "gliders" and thinking about stuffing some totally illegal but fun power plants in them
I was looking for a cheap engine dyno to stress test some engine parts and I think I found it. 6k for a glider, 8k for one with tranny and the dry sump soooooo tempting
Brent I'll get with you soon and get you some rockin block beams to 6 bolt stock blocks and stress that tranny 1500 furry ponies would be a good start!!!
rockin blocks will do it. I'll do another build thread. this tranny would be the most fun you can have with clothes on.
Old Dec 18, 2020 | 09:08 AM
Supporting Vendor
that sounds amazing Ron. Please forgive my failure to reply sooner. I'm excited to see what you have going. I'm assuming you still have my cell#. Give me a shout sometime.
Bret
Old May 26, 2022 | 01:39 PM
Supporting Vendor
A 29 spline input shaft is now an option. I have the ability to get custom hubs made for RPS, Monster and Tilton clutch so far and possibly Mantic. They're made from 300M as well. The 26 flying is also available in 300M. We're also making hubs for the other end of the torque tube from 300M since we had customers breaking the stock hubs.
Old Apr 4, 2024 | 02:27 PM
Supporting Vendor
Now we have the 6XD-X which is capable of holding 3000hp with ease. Please contact me directly with any questions. Buying from me includes my support.
Old Jun 24, 2024 | 04:39 PM
Supporting Vendor
Thanks for your continued support!
Old Jun 27, 2024 | 11:24 PM
CASEWORER's Avatar
CASEWORER
Would love to be able to afford one of these.
To The ultimate trans/ diff package. Billet sequential with quick change rear end
