Im looking @ some small blower cams for my 09 LS3 ( yes I want to keep it small, think Ghost or sleeper Cam )
Street driven ECS Novi 1500 Kit Auto Trans Stock Convertor E85 stock manifolds with CATs, 2.5 inch magnaflow cat back , NO Mufflers. TUNED.
Goals are just sleeper street, Low 11's high 10's retain 100% drivability This car is not my race car, its my grocery getter.
Note please don't suggest a 3800 stall and a huge cam, I may put a 2800-3200 stall in it later but not required for this, I know many of you run larger cams and convertors on the street and enjoy it, and I respect that.
I feel like the second cam would be a turbo grind but would work perfectly for the centrifugal..... ? neither cam has much overlap so it should fly under the radar.
which would be the better cam of these two?
1st Cam
Lift Intake .581 Exhaust .588 Installed @116 Centerline Lobe sep = 116
Dur @ .050 220 228
Valve timing OPEN CLOSE
INTAKE 6- BTDC 46 ATDC
Exhaust 50 BBDC 2- ATDC
Something with ~220/230 duration, ~.600” lift and ~115*LSA with ~+3* advance would be the ticket for a nice street cam which is blower friendly. But, it won’t be a “sleeper”, because it will still have a slight chop to it - how much will depend on idle speed and your tuners ability.
If you want a real sleeper cam, something like the stock LS9 specs would work, but for most folks, that’s not worth the trouble for the hp gain you will see from it.
For me, that would be perfect for anyone with a centrifugal SC.
For a positive displacement SC .... The same specs except an LSA of about 119* (since the PD blower makes power right off idle, the 119* LSA would bring that power on at a higher rpm)
Im not opposed to some small Lope, most guys around here run cams with alot of overlap so you can hear it pretty easy. I do have a very good tuner and I think you are right on the Ls9 cam. Thanks!
Have you looked into any of the cams made specifically for LS3 centri blower applications? BTR makes two different versions of theirs, but the smaller version works really well and is somewhat docile.
Ive looked at their stuff but nothing struck me as a fit but i could have missed one, they have alot of cams lol do you have a specific one you know of or a link to one? id love to see their specs.
EDIT i think I found the one you are referring to and I like it. A&A SUPERCHARGED CAM Specs: 220/230 .581/.591 116+3
That cam sounds just about perfect for a daily driven, weekend warrior blower setup.
Yeah that might be the perfect choice for what you are looking for. Not crazy but still will work really well.
I run a BTR LS3 Centri Blower cam which works awesome. Makes good power for sure. Sounds great too. I am super happy with it. But it might be a little more than you are wanting
I run a BTR LS3 Centri Blower cam which works awesome. BTR CAMSHAFT - LS3 - CENTRIFUGAL SUPERCHARGED 227/244 .618"/.604" 115+5
That is a good bit of lift. How noisy is your valvetrain and what interval are you changing springs? I am currently running a 232/234 .590 112 LSA cam and ours sound very similar. I went H/C/I on the car first but I bought a Maggie kit. I haven't installed it yet but I am debating on whether or not swapping to a blower cam is worth it. Some guys say NA cams work well enough that its not worth the trouble to swap for the power difference between the two. My cam pulls hard in the upper rpm which would suit a Maggie well.
I plan to test the springs this Spring, and if they are all good probably replace them at 20k. They are BTR springs so they are really good quality. My valvetrain noise isn't awful, its masked by the supercharger noise pretty well. NA cams can work well "enough" with a SC, but are they perfect...no. Having specific dedicated cam timing for a blower application allows more power on less boost. Win win! Is it worth swapping out cams if you already have a decent NA cam though? Tough question.
so they sent me this cam you have by mistake. Came in today do you run a stock convertor? which springs? yes its a lil big for my lil UTR girl ( under the radar )
I was running the stock converter which was fine. I am switching to a Circle D 3200 though while I am upgrading my transmission. I use BTR Platinum Dual Springs rated up to .660" lift with titanium retainers.
