C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Clutch tamer
Old Feb 16, 2021 | 01:27 AM
Felipe_z06's Avatar
Felipe_z06
Default Clutch tamer
I been want to install a clutch tamer like a hitmaster or a magnus launch control device I have heard good thing about them to get more competitive at the track. Main question is the lines from slave to master anyone ever install one? Really want to know what lines to buy to install one on my c6z with stock slave and master.
Old Feb 16, 2021 | 08:53 AM
m60gov20's Avatar
m60gov20
I just got one. I haven’t installed it yet though. I couldn’t make since of how it worked until I got it. I think it will work great.
Old Feb 16, 2021 | 10:18 AM
Felipe_z06's Avatar
Felipe_z06
Any pics of headwear do I have to flair lines? Did u buy a kit?
Old Feb 16, 2021 | 10:27 AM
HowWhyWhyHow's Avatar
HowWhyWhyHow
Not sure how you'd install one with the c6's throw out bearing design.
Interested in it though!
Old Feb 16, 2021 | 12:50 PM
Felipe_z06's Avatar
Felipe_z06
I wouldent even mind slapping an aftermarket one
Old Feb 16, 2021 | 01:02 PM
HowWhyWhyHow
I meant to say slave cylinder design.
Old Feb 17, 2021 | 10:39 AM
Felipe_z06's Avatar
Felipe_z06
Only seen one guy use it
Old Feb 23, 2021 | 01:18 PM
FourG63 97GST's Avatar
FourG63 97GST
good question, when I did my slave, I switched to to AN lines, instead of the oem push lock. I connect the master and slave your a AN male male union fitting.
Old Feb 23, 2021 | 09:08 PM
Felipe_z06's Avatar
Felipe_z06
were can I find this fitting and do I have to pull the salve out to do this?
Old Aug 21, 2021 | 02:33 PM
pmwinc's Avatar
pmwinc
any updates on this?? I am trying to figure out how to connect to stock lines. are those lines -3 or -4??..TIA
Old Aug 21, 2021 | 04:38 PM
Felipe_z06's Avatar
Felipe_z06
yes sir I got mine all hooked up and plumed with -4 lines
Old Aug 21, 2021 | 05:04 PM
pmwinc's Avatar
pmwinc
How did you graft it in?? Pics?? TIA!!
Old Aug 21, 2021 | 05:19 PM
Felipe_z06's Avatar
Felipe_z06
I’m currently not in town but I’ll be home tomorrow and can send pics I pretty much used a cutting ring fitting
Old Aug 21, 2021 | 07:37 PM
pmwinc's Avatar
pmwinc
Thank you!!!
Old Aug 22, 2021 | 08:54 AM
pmwinc's Avatar
pmwinc
OK, been around car for 40 yrs...what is a cutting ring fitting??? thx
Old Aug 22, 2021 | 03:05 PM
Felipe_z06's Avatar
Felipe_z06
cutting ring is a ring that cuts into a hard line and make a super tight fit. Stock clutch line is 6m this is what you are going to need bellow and also you will need a brake line cutter. I cut the stock line while it was hooked up in the car and it was no problem without removing the header. Then i went to a hydraulic store and had them make me -4 fitting to a hydraulic line and hooked everything up.
2x 9606-04-S06-14 1/4" JIC Male x M14x1.5 Metric Male
2x 5204S-06 DIN 2353 S Soft Seal Tube Cap
2x 5202-06 DIN 2353 Cutting Ring
Old Aug 22, 2021 | 07:19 PM
pmwinc's Avatar
pmwinc
so,how has it help your launches or dropped your 60' times??
To Clutch tamer
Old Aug 22, 2021 | 07:36 PM
Felipe_z06's Avatar
Felipe_z06
Mine is pretty much on a button and I just hold the button down and floor the gas on the two step and pop clutch as fastest I can while holding down the bottom after I hit about 30 mph I let go. I do 1.3 60ft on 17in welds and about 1.5 on the street same launch every single time took me about 4 passes to get it dial in.
Old Aug 23, 2021 | 08:10 AM
pmwinc's Avatar
pmwinc
I have a C5Z, still stock trans/diff, so if I could get 1.5s, and not break anything, I will be very happy! 1.8 60' 10.8@135 so far.
Old Aug 23, 2021 | 11:21 AM
pmwinc's Avatar
pmwinc
Felipe_z06 Which device did you use????
