C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Supercharger
Old Feb 20, 2021 | 09:34 PM
Speedy52's Avatar
Speedy52
Cruising
Default Supercharger
I have a 2006 c6 base corvette can I add a supercharger with out a cam kit with out hurting my engine and how much hp would I gain? I've been told my c6 stock has 345 to 350ish is that correct? my first corvette so trying to get some feed back thanks.
Old Feb 20, 2021 | 09:50 PM
playtoy's Avatar
playtoy
Quick answer is yes, but some things will need to be upgraded such as the clutch if you have a manual trans.
Power depends on what you are willing to do to the car. Just a centrifugal supercharger with a boost a pump and injectors can get you around 500 rwhp. If you add meth and exhaust around 550. Longevity of the motor will mostly depend on your tuner and how you care for/drive your car
With that being said anything can happen even with no supercharger, might as well have fun with it.
Old Feb 21, 2021 | 03:54 PM
Spaceme1117's Avatar
Spaceme1117
2006 Base Corvette will have the LS2 (6.0 L V8). Crank horsepower is 400. Probably about 350 to the wheels with an automatic trans. A little more if a manual.
No, you do not need a cam with a supercharger. There are complete kits that are bolt on that come with everything including a tune.
Magnuson Heartbeat, Edelbrock E-force, ECS, and A&A are the main superchargers for our cars. The first two of those are positive displacement types; the second two are centrifugal (basically a belt-driven turbo).
Positive displacement superchargers produce steady boost at all RPMs and max torque starting very low so are very fun for stop light to stop light street driving. They are extremely reliable and require almost no maintenance.
Centrifugal superchargers build boost more and more as RPM's go higher and tend to make more top end power. These usually require regular oil changes for the supercharger unit (not a big deal really).
None of these will make your engine any less reliable at horse power levels of 500 to 600 hp.
Now, other supporting mods can and do enhance power generation; cam, heads, headers, methanol injection, etc. But these are not necessary.
Just adding a supercharger also won't affect the driveability either.
Old Feb 28, 2021 | 01:32 PM
NYC6's Avatar
NYC6
About ten years on my 06 with an A&A T-trim. Puts 540 to the ground and reliable as the day is long. The LS2 is a stout motor. Think I’m going to be swapping to a smaller pulley and add meth this year up the power some.
Do it you’ll love it
Old Feb 28, 2021 | 01:56 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
The OP can forget using the Magnuson Heartbeat SC since it won't fit on the heads of an LS2.
Old Mar 1, 2021 | 12:32 AM
Lowlygovemployee's Avatar
Lowlygovemployee
2nd Gear
Veteran: Marine Corps
I have a box stock ECS kit for an LS2, full exhaust, including Kooks 1 5/8 headers, Kooks catted x pipe, and SLP Loud Mouth 2 axle back. It made 589/540 Tuned by MS Tuning in Houston TX. The car drives great, I would say almost like stock. The clutch has held up, mainly due to the factory Goodyears suck for traction. I would highly recommend adding boost to your ride.
Old Mar 5, 2021 | 07:32 AM
Spaceme1117
Good point. Thanks.
Old Mar 9, 2021 | 02:36 PM
JUICED1's Avatar
0JUICED1
Former Vendor
We regularly make around 525-600 rwhp with no cam on supercharger kits. They are plenty safe with proper tuning and a good fuel system.
With a cam we can generally add another 50-75 rwhp. We've brought some stock bottom end cars into the 700rwhp range and had some success but I wouldn't push any further then that.....well not without a back up plan.
Old Mar 9, 2021 | 04:40 PM
LSX228R's Avatar
LSX228R
a&a kit + headers. I still have the stock clutch and going on 5 years with no issues.
To Supercharger
