C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
E85 conversion
Old Mar 8, 2021 | 10:21 AM
JJ 86's Avatar
JJ 86
Default E85 conversion
What’s needed to convert to e85 on my 08 base? Still want to be able to run regular 93 as well. Current mods are Longtube headers cat-less x-pipe, B&B axle back, A&A V3 si with 3.8 pulley, and 60lb injectors. It made 550 rwhp and 505 rwtq.
Old Mar 8, 2021 | 01:47 PM
bigron1212's Avatar
bigron1212
You are going to need to upgrade in the in tank pump to a walbro 450 or 525 and also upgrade your injectors.....
I suggest the Racetronix 525 pump w/wiring harness and ID 1050's.
Old Mar 8, 2021 | 01:53 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Larger fuel system, larger injectors, flex fuel sensor kit, tune
Old Mar 8, 2021 | 02:31 PM
VVVROOMTX's Avatar
VVVROOMTX
AA corvette dual pump system or an in-tank dual pump from Fore
Bigger injectors (depends on desired power)
Flex fuel sensor
Re-tune
Old Mar 13, 2021 | 02:48 PM
JJ 86's Avatar
JJ 86
How much HP can the stock fuel pump support? Is it possible to run E85 with the stock pump?
Old Mar 13, 2021 | 07:02 PM
m60gov20's Avatar
m60gov20
No, that wouldn’t be a wize choice. Your injectors won’t be big enough either. I did an ECS stage 1 e85 fuel system, dsx flex fuel kit and id 1050X injectors.
Old Mar 15, 2021 | 01:14 PM
VVVROOMTX's Avatar
VVVROOMTX
Absolutely pointless
Old Mar 16, 2021 | 11:58 AM
HouseS2k's Avatar
HouseS2k
A fuel system is not the place to be cheap.
To E85 conversion
