C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
E85 and e-force supercharger
Old Mar 13, 2021 | 11:59 AM
ttchybrid's Avatar
ttchybrid
Default E85 and e-force supercharger
I have a 2010 GS with auto and the 599 hp e- force kit. This kit comes with the z06 fuel pump. Will this z06 fuel pump put out enough flow with 850 injectors?? Will e85 damage the pump??
thanks
Old Mar 14, 2021 | 11:48 AM
GX427's Avatar
GX427
Yeah the z06 pump definitely won’t support that they max out like 515whp on NA setups if that
Old Mar 19, 2021 | 12:22 AM
Charliemopic's Avatar
Charliemopic
My C6 base has the base Eforce that did not come with the Z pump.
Its at the shop now getting a small cam, DSX flex fuel, ID 1050x injectors and A&A twin pump and 3.5" blower pulley.
The tuner will know if its adequetly fueled.
We shall see how it goes in a few days.
Pics from installer Speed Inc.
Old Mar 23, 2021 | 10:57 PM
Farmvette's Avatar
Farmvette
Picked up my Z06 from the tuner yesterday after flex fuel conversion. It's making 559 whp on E85 (548 whp on 93) with a stock pump and 60 pound DEKA injectors at 73% duty cycle per the tuner. Having the same conversation with another 599hp E-force LS3 owner currently. I'm thinking that if you want to go E85 you could install the sensor and get it tuned. If it works, you're fine. If you need more pump then just run on gas until you get a (aux) pump upgrade, and you are only out the cost of the first tune.
Old Mar 24, 2021 | 09:16 AM
JetstreamGS's Avatar
JetstreamGS
If you’re dropping the tank to put in a stock Z06 pump might as well get something dedicated to running corn.
Old Mar 24, 2021 | 09:17 AM
JetstreamGS
No they don’t lol
Old Mar 24, 2021 | 08:33 PM
Spaceme1117's Avatar
Spaceme1117
thanks
E85 won't damage the pump.
I would add a Boost-A-Pump if you are going to run e85. Easy upgrade.
And its a good idea to add a Racetronix fuel pump harness regardless of what you do.
Old Mar 27, 2021 | 09:36 PM
GX427's Avatar
GX427
How far can I push the stock pump e85 NA?
To E85 and e-force supercharger
