C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Blower cam help!
Old Mar 15, 2021 | 08:54 AM
ProjectSunrise's Avatar
ProjectSunrise
Default Blower cam help!
Due to unforeseen issues I am dropping the entire drivetrain from my c6, and while I have it out I’m going to put a cam in it, question is what cam is going to work best for my ECS supercharger I’ve got sitting here waiting to get installed. It’s a 6 speed so no worries about the torque converter, I was going to do methanol injection but I feel the cam is a better way to get the power. I’ve looked at the ECS big blower cam, and some texas speed cams, I know there is a lot of options out there but I’m looking to be in the 650 hp to the wheel range.
Thank you!
Old Mar 15, 2021 | 09:23 AM
VVVROOMTX's Avatar
VVVROOMTX
Thank you!
BTR. Easy and done. Will you still be on pump gas or E85?
Old Mar 15, 2021 | 10:35 AM
Unreal's Avatar
Unreal
BTR, Done and Easy.
Old Mar 15, 2021 | 10:42 AM
ProjectSunrise
I will be on pump gas, E85 isn’t readily available where I am.
Old Mar 15, 2021 | 01:07 PM
VVVROOMTX's Avatar
VVVROOMTX
Ok if you are going to be running 93 or 91, you REALLY should get a meth system on the car
Old Mar 15, 2021 | 03:28 PM
D-Dub2013's Avatar
D-Dub2013
BTR Centrifugal Blower Cam
Old Mar 15, 2021 | 04:49 PM
ProjectSunrise
I do have a brand new alky methanol kit sitting in a box. Should I run it as well? I wasn’t going to but I have it sitting in the box.
Old Mar 15, 2021 | 05:30 PM
Unreal's Avatar
Unreal
Yes, why would you not install it?
Unless you are just going for a very basic 500-550hp setup, and in that case, skip the cam, and just don't do anything but the blower.
Old Mar 15, 2021 | 11:04 PM
ProjectSunrise
i want at least 650 hp at the wheels, I’m dropping the entire drivetrain tomorrow and putting the engine on a stand. Going to talk to my engine builder to see if it’s worth it to put forged pistons in it while the engine is out. Then if I decide later I can crank it up and not worry about it.
Old Mar 16, 2021 | 09:28 AM
VVVROOMTX's Avatar
VVVROOMTX
You do realize that the LS3 in stock form will handle a ton of horsepower reliably right? If you want to make 650 that's fine but with a cam, meth and blower you can make 750rwhp super reliably. No need to build the motor unless you want to venture into the high 800s and beyond
Old Mar 16, 2021 | 09:34 AM
ProjectSunrise
I have the LS2 not the LS3, and no I don’t know what the limit is on the stock bottom end. I just know I’ll have the engine sitting on the engine stand tonight and I don’t want to have to pull it again to do something I wish I would have done. I don’t plan on taking this car into the high 800hp range. 650 to 750 should be sufficient for a play toy.
Old Mar 16, 2021 | 09:48 AM
VVVROOMTX's Avatar
VVVROOMTX
LS2 or 3 can make 800rwhp all day. My car has been damn near 1000 crank for 2.5 years now. But if you are going to have the engine on a stand, a good rod, piston, ARP hardware and Melling oil pump would be awesome to throw in. Then make what ever your blower can make
Old Mar 16, 2021 | 10:30 AM
Unreal's Avatar
Unreal
Pistons alone are rarely worth it. Doesn't get you much for the cost. Either do everything, or nothing. Stock ls2 will take that power all day long. The machine work/cost of pistons just is not worth it unless you want to do rods and other items while in there.
Old Mar 16, 2021 | 10:33 AM
ProjectSunrise
How safe is the LS2 at that power level? I don’t want to be right at the max flirting with disaster if I can help it.
Old Mar 16, 2021 | 11:06 AM
VVVROOMTX's Avatar
VVVROOMTX
500-750 is still pretty safe in my opinion with a good, knowledgeable tuner. Past that you understand the risk is going to go up with power. But there are lots of cars that make 8-900 hp with SBE Ls2 and 3 and live for a longgggg time.
Old Mar 16, 2021 | 12:02 PM
Unreal's Avatar
Unreal
<850 and don't touch it. Keep tune safe and octane high.
Old Mar 16, 2021 | 12:34 PM
ProjectSunrise
Ok great, thank you! I guess I’ll just leave the bottom end alone then. No need to do it if it’s not needed I just wasn’t 100% sure.
To Blower cam help!
Old Mar 17, 2021 | 06:55 AM
BIGMAC's Avatar
BIGMAC
Thank you!
I have the ECS "Big Blower" cam (made by Comp Cams) and just like Goldilocks and the Three Bears it is "just right" in my set up.
Old Mar 17, 2021 | 10:19 AM
FAKEZR1's Avatar
FAKEZR1
I am also getting ready to install an A&A centrifugal cam in my C6. Here's a sound clip for reference, not my car of course....
Old Mar 20, 2021 | 11:49 AM
ProjectSunrise
Default Pistons and rods
So tearing my LS2 apart my brother and I found part of the timing chain guide in the bottom of the oil pan near the pick up tube. That chunk of metal got beat around in the bottom of the engine... and since the timing chain was loose a couple of the pistons had valve marks on them. Hadn’t planned on putting pistons and rods in it but here we go, she will define ready for some boost
