C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Inconel valves
Old May 10, 2021 | 07:38 PM
SteveJewels's Avatar
SteveJewels
Default Inconel valves
On a boosted engine, at what WHP level does an Inconel exhaust valve become advisable?
Thanks!
Old May 10, 2021 | 09:48 PM
GAMEOVR's Avatar
GAMEOVR
From what I’ve been told it’s anything above 1k, but depending on heat from boost it could be used below that just for reassurance. It’s still a stainless valve it just has the inconel properties embedded into it so it’s still a heavy valve.
Old May 12, 2021 | 03:39 PM
Pb82 Ronin's Avatar
Pb82 Ronin
Inconel is decently heavier than a steel valve. I wouldn't even consider it unless steel valves were going to let you down or under perform in some way.
Old May 14, 2021 | 04:08 PM
VVVROOMTX's Avatar
VVVROOMTX
Unless you are going to making ALOT of power and heat they aren't really needed. Something like a big power blower/turbo setup or a big n2o setup especially. Obviously they are better than SS but ehat really helps to not burn upp valves is proper valve seating. A good seat and bowl job would be advised as well./
Old May 17, 2021 | 08:51 PM
Chiselchst's Avatar
Chiselchst
IIRC, most V8 boat engines only run Inconel valves and valve seats...FWIW
Old May 19, 2021 | 02:14 PM
VVVROOMTX's Avatar
VVVROOMTX
Probably due to corrosion
Old May 22, 2021 | 10:48 AM
Chiselchst's Avatar
Chiselchst
I've read it's only required on exhaust valves & seats, for heat. Seems to be a marine staple.
IIRC
Old May 26, 2021 | 10:59 AM
Rkreigh's Avatar
Rkreigh
as you do a sustained high boost pull the egts can get pretty toasty and the inconel valves make sense.
go rob the ly6 truck heads, they come with stock chevy iconel
I'm going to try and coat some TI exhaust valves and run e85 for cooler egts and on the street they will live
indy and boats do sustained WOT and inconel becomes a necessity not a luxury
To Inconel valves
