C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Injector size help
Old Jun 16, 2021 | 01:56 PM
doomi's Avatar
doomi
Default Injector size help
I'm gearing up to install a Fore double pump system in my LS3 with the intent to move to E85 for the most part, but will keep flex. I'm currently making 747whp and wouldn't mind a little more power, but I'm not interested in pulleying down currently.
I've been recommended to go in the FIC 1300 range for injectors, but I wanted to double check here as well. Also, my tuner is recommending Fuel Injection Clinic which seemed odd based on most folks preference for FIConnection or ID. Thoughts?
My current setup:
A&A V2 Ti trim supercharger w/ 3.6" pulley
Alky Control dual nozzle meth
Stock fuel pumps with BAP and 80# injectors
BTR Stage II cam
Old Jun 16, 2021 | 02:01 PM
sstonebreaker's Avatar
sstonebreaker
If you're happy with your current fuel injectors, then to run E85 you need to increase the size by about 50%. E85 runs about 9:1 air/fuel, gas ar about 13:1 in power enrichment mode. So you need to put injectors about 13/9ths the size you currently have.
Old Jun 16, 2021 | 02:20 PM
doomi's Avatar
doomi
Thanks, sstonebreaker. Based on that it looks like I could go with Fuel Injector Clinic 1200CC and still have headroom.
Old Jun 16, 2021 | 08:13 PM
Daddy Freeman's Avatar
Daddy Freeman
I run ID 1300's on E85 and Fore triple system with YSI blower at 15lbs and my injector duty is around 65% if that give you an idea. Making a hair over 1000 at the wheels.
Old Jun 17, 2021 | 11:20 AM
doomi's Avatar
doomi
Thanks for the info!
Old Jun 17, 2021 | 04:26 PM
JJ 86's Avatar
JJ 86
My current setup:
BTR Stage II cam
By chance do you know what your injector duty cycle is at your current power level?
Old Jun 18, 2021 | 11:15 PM
doomi's Avatar
doomi
I can't remember and can't find it unfortunately.
Old Jun 22, 2021 | 03:17 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I'd go with ID1300's for that setup personally. They are awfully proud of them though, not cheap
Old Jun 22, 2021 | 06:06 PM
icanski2's Avatar
icanski2
St. Jude Donor '13
ID1300's will give you plenty of capacity but they can still be tuned to not run like a pig on the idle RPM side of the tach. I have a set going in my 416 YSi build with a Fore triple setup. (If I can ever get time to work on it again that is.....)
Old Jun 23, 2021 | 04:45 PM
doomi's Avatar
doomi
Thanks for the advice. ID sure is proud of their stuff with their prices.
Old Jul 8, 2021 | 11:51 PM
doomi's Avatar
doomi
Still trying to decide what to do and where to spend my dollars.
I came across a deal on fuel injector clinic 1650s. Is that just complete overkill here? I'm having a hard time getting hold of my tuner this week
Thanks again for all the advice.
Old Jul 9, 2021 | 08:39 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Kind of, sort of, not really. I've tuned ID1700's on a similar setup to yours and it was fine. I have no idea if the data for FIC 1650's is as accurate though, and that's really the key.. I haven't tuned any of those yet. If the data is good, they'll work fine. If it sucks, they could be a pain.
Old Jul 9, 2021 | 11:32 AM
doomi's Avatar
doomi
That's kind of what I was thinking. I need to just buy the right injectors for my application. I don't want to add any headaches.
Thanks for the info.
Old Jul 12, 2021 | 11:59 AM
sstonebreaker
There's a reason the factory puts the smallest injectors they can on the car. Lingenfelter has also said that he aims for an 85% duty cycle on the injectors at max effort on his builds. As I recall, it had to do with homogenizing the mixture as much as possible. This can be more important on cars with ported heads, as the porting jobs can reduce the tumble and swirl actions of stock heads, in the name of maximizing flow.
Old Jul 12, 2021 | 12:37 PM
doomi's Avatar
doomi
I went ahead and got the ID1300s based on the recommendations in this thread.
Old Jul 13, 2021 | 10:34 AM
Unreal's Avatar
Unreal
Injectors are not the place to save money or skimp. ID1300 or 1700 should be the only real choice.
To Injector size help
