C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
BTr intake?
Old Jun 21, 2021 | 09:33 PM
GX427's Avatar
GX427
Default BTr intake?
https://briantooleyracing.com/btr-eq...age-btreq.html
is this intake any good?
Old Jun 22, 2021 | 09:55 AM
BT03mach-1's Avatar
BT03mach-1
I'm working on getting this LS3 Holley Low Ram to fit. Hopefully I have it running this weekend
Old Jun 22, 2021 | 11:38 AM
GX427's Avatar
GX427
Wonder if those are any good hmm
Old Jun 22, 2021 | 05:01 PM
da6speed's Avatar
da6speed
Nice! I wasn't aware they finally released it. Are you using the rails that came with it or standard Holley fuel rails?
Old Jun 22, 2021 | 05:56 PM
BT03mach-1's Avatar
BT03mach-1
Rails that came with it. I think you have to because the injectors sit a little to the side. If you look at the driver side you can see the raised parts. That's each injector location. i think it's like that because they have a dual injector option.
My Holley rails for a stock intake wouldn't work.
Old Jun 22, 2021 | 06:48 PM
icanski2's Avatar
icanski2
St. Jude Donor '13
Keep us updated on this. I'm trying to figure out what I'm going to do in the intake department for my YSi. I have a ported Fast 102 but I'm not sure of the longevity of that intake with F.I.
Old Jun 23, 2021 | 03:25 AM
lt1z's Avatar
lt1z
The BTR intake works well if you are running 7500-8000rpm.
Old Jun 23, 2021 | 09:30 AM
BT03mach-1's Avatar
BT03mach-1
That's why I switched because I'm switching to a F1a-94. It was the cheapest intake for boost without being sheet metal. Hopefully it works because I think it looks good and doesn't require any cutting. Things had to be relocated but that's about it.. So far anyway.
Old Jun 23, 2021 | 11:25 AM
FourG63 97GST's Avatar
FourG63 97GST
First priority is if it fits the powerband that you'll be using the car, and it if fits. It's a good intake if it fits your criteria.
Old Jun 26, 2021 | 06:38 AM
wesam's Avatar
wesam
Please Update us abouth the results
What intake do you have before that ? Dyno comparison will be perfect
Thanks in advance
Old Jun 27, 2021 | 12:17 PM
GX427's Avatar
GX427
I just wanted a metal intake Incase I boost further than 25psi
Old Jun 28, 2021 | 08:01 PM
wesam's Avatar
wesam
any update ?
Old Jun 29, 2021 | 08:57 AM
BT03mach-1's Avatar
BT03mach-1
Yeah I got it installed. No fuel leaks and it held 25psi just fine. I haven't started it yet because I'm installing V-bands on my exhaust and I broke my shifter cable installing a flexplate. I plan to start it this weekend unless I screw something else up. I also ran -8 fuel lines preparing for my new blower. This weekend project has turned into a 4 week project LOL.
I won't be able to tell much after I get it running because I'm not taking it to get tuned till I install my F1a-94. Any adjustments that need to be made I will do them on the street.
Old Jun 29, 2021 | 09:56 AM
da6speed's Avatar
da6speed
Man, it'd be nice to see somewhat of a back to back comparison with same blower vs whenever you had it tuned last. But I understand doing it all at once with the new blower.
Old Jun 29, 2021 | 11:57 AM
BT03mach-1's Avatar
BT03mach-1
Yeah sorry about that! My car may not be a good comparison anyway since it has a 427 in it and not a ls3.
Old Jul 4, 2021 | 02:06 PM
couselor's Avatar
couselor
I’m running trinity ls7
Old Jul 4, 2021 | 02:36 PM
wesam's Avatar
wesam
so bad they did not make a dual injector version
To BTr intake?
Old Jul 6, 2021 | 09:41 AM
BT03mach-1's Avatar
BT03mach-1
That intake looks good!
Old Aug 9, 2021 | 06:11 PM
wesam's Avatar
wesam
Any update ?
I just want to see the dyno graph and to see how is the torque curve looks
Old Aug 10, 2021 | 09:31 AM
Nursing Nevada's Avatar
Nursing Nevada
What coil pack Harness did you use?
