Looks like something went through it. They don't just come apart. How does the airfilter look? Any chunks missing? Ever ran without a filter or with a race filter/etc? Doesn't take much to cause major damage when it is spinning at 50k rpm.
As for eating metal or into the motor, it would have to make it through the intercooler, which has fairly small passages, so the risk is low, but he should be taking all the pipes off and cleaning out and checking for sure.
The filter is in good shape and clean, minus the impeller pieces laying in it. No, I have never run the car without the filter. There is no visible damage to the the throttle body. The blower discharge pipe has some small debris in it, but the intercooler looks to be ok. Definitely taking it apart to inspect everything and clean.
Those prices seem way way way off. Are you going off random 3rd party sites or vortech? Vortech typically needs the unit in hand, then will quote a repair. I've had a case replaced, all new bearings/internals and it was less than $700 with return shipping.
Those are the prices at Jon Bond Performance that someone earlier recommended. I am personally sending mine to Vortech.
That's reasonable. Was that with a new impeller too?
The impeller at Jon Bond is $574.99. Little different than $100.
I was a little off on the impeller. lol. But a stock replacement is $400. The billet one is $575.
I bought my D1SC that was mangled up for $500. I put $500 into it with bearings and such. So i think I made out ok. These things are stupid simple to work on. A Torch and a press go a long way.
