C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
SBE LS3 D1SC dyno’d
Old Oct 22, 2021 | 02:39 PM
Nursing Nevada's Avatar
Nursing Nevada
Default SBE LS3 D1SC dyno’d
2008 Base LS3/6060 car
So finally broke my clutch in and all that jazz. Car originally made high 5’s with LTs and a V3Si on 7lbs (3.8 pulley)
New setup, D1SC with A&A bracket, Flip drive, IW 10% OD, 3.8 upper pulley, BTR Centri Cam (older version). E85 and a home made A&A style secondary fuel system. FIC1000 injectors. And of course all the supporting stuff, head studs, oil pump, RXT clutch etc.
60% E content. IATs in the 180s (after many back to back pulls and the dyno fans weren’t the best) Started to max the injectors. But here are the results. Only getting 11 degrees of timing up too because of the IAT.
I really wanted 8’s. And I’m sure I can get there with bigger injectors and cooler IATs. But the midrange is insane. And the TQ curve is 👌🏻
Old Oct 22, 2021 | 03:22 PM
old motorhead's Avatar
old motorhead
That is a torquey ****! A meth system would do you worlds of good IAT wise and take a little pressure off of your injectors.
Old Oct 22, 2021 | 04:34 PM
JetstreamGS's Avatar
JetstreamGS
Took the words straight out of my mouth.
Old Oct 23, 2021 | 12:01 PM
bigron1212's Avatar
bigron1212
Impressive Tq curve for a Centri! Almost looks like a PD blowers tq curve.
Great numbers!
Old Oct 24, 2021 | 08:15 PM
Detoxx03's Avatar
Detoxx03
One of the best street blowers out there. Throw some meth on there even when you get bigger injectors.
Old Oct 25, 2021 | 10:10 AM
Nursing Nevada
I really wanted to be in the 800s, like you. Probably go with a 3.7 upper next, after injectors. Only hit 14.6lb of boost. Could possibly be getting belt slip. Is there any way to tell if you are?
To SBE LS3 D1SC dyno’d
