C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Fuel and blower capability question
Old Dec 21, 2021 | 04:15 PM
Nikoslab_Z06's Avatar
Nikoslab_Z06
Default Fuel and blower capability question
Hey all, I have a 2008 Z06 with a built ERL superdeck 6 bolt block, a cam by james short (246/254 112LSA 108icl 0.652/0.630) AI 280cc heads, Mantic Triple Disk, MSD Atomic intake, LG 1 7/8 headers, catless x pipe, gutted stock mufflers, Walbro 450 LPH, LS9 injectors and a dsx E85 flex fuel sensor kit. Considering going the Forced Induction route. I know the cam isn't the greatest for boost, but how far power wise am I looking with a Ti trim (V1 probably to spin it faster) 95lb/hr injectors and a BAP? Kind of want to avoid dropping the tank this year (or altogether). End goal is 850-900whp on E85. Will that setup hold that much power? Will the blower even make it that far or should I just go straight to the Ysi or D1X?
Thanks!
Old Dec 21, 2021 | 04:39 PM
helga203's Avatar
helga203
Thanks!
Those will work. If later on u want more go with f1-x
Old Dec 21, 2021 | 05:53 PM
Nursing Nevada's Avatar
Nursing Nevada
I would go with a D1X.
Old Dec 22, 2021 | 08:31 AM
Nikoslab_Z06
do you think If I added the bap and injectors I’d be fine fuel wise?
Old Dec 22, 2021 | 09:43 AM
Nursing Nevada
With your 450 intank. I would do a AEM 400 external. And 1100cc injectors at a minimum
Old Dec 22, 2021 | 06:50 PM
Detoxx03's Avatar
Detoxx03
D1X but you’re gonna need a better fuel setup
Old Dec 22, 2021 | 07:18 PM
Nikoslab_Z06
would the a&a double pump system do?
Old Dec 22, 2021 | 11:17 PM
srm077's Avatar
srm077
You need more injector and pump for sure. Honestly- AA fuel system is nice overall and I'd do at least a 1200cc injector. Personally- I ran out of fuel on a 1200cc injector with 2 large meth nozzles on a D1X. I went to 2150's but I'm a max effort setup and mine is making way more then it should based on the D1X cfm. The D1X is a bad little bit$h. I am also overspinning the **** out of mine. Edit to say I'm on a 450 in tank at 14.5 volts and a Magnafuel 4303 that is 18 volts. I run E and stay at 75 ish E content. I try and race on VPX85 when possible. I have some FIC 1200's that have a few dyno pulls for anyone looking...
Old Dec 23, 2021 | 09:50 AM
Nursing Nevada
What are you looking to get for the FIC's?
Old Dec 23, 2021 | 10:34 AM
Nikoslab_Z06
Awesome! This sounds like the route I’m probably going to take. If you don’t make a deal with Nursing Nevada, shoot me price and info on the 1200s
Old Dec 23, 2021 | 08:26 PM
srm077's Avatar
srm077
850 shipped.
Old Dec 26, 2021 | 05:16 PM
slowtealz28's Avatar
slowtealz28
T trim can’t get you even close to what your motor should be able to handle. If your end goal is 800-850 the T trim is fine. I personally would do something like a d1x or f1a94 to really allow it to shine but like others said you’re gonna need more fuel system. I think that cam will work fine with a centri blower just because most NA cams work well with them.
Old Dec 27, 2021 | 01:41 PM
VVVROOMTX's Avatar
VVVROOMTX
With a 427 that can handle boost why waste time with a T trim? I would get a YSI or a even better a D1x. You can always pulley down but you cant ever go higher than a maxed out blower.
Also i recommend more fuel pump and at least 1100cc injectors. I run FIC1300s
To Fuel and blower capability question
