C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Ecs kit tensioner alignment
Old Apr 30, 2022 | 08:09 PM
jusmillz's Avatar
jusmillz
Default Ecs kit tensioner alignment
Which do you turn to help angle the tensioner for alignment ? My belt keeps jumping ribs
away from the motor
Old Apr 30, 2022 | 10:50 PM
russ472's Avatar
russ472
it probably isn't the tensioner. its probably one of the other pulleys causing the issue. you need to get a laser alignment tool to find the problem
Old May 1, 2022 | 09:55 AM
helga203's Avatar
helga203
Possibly, but 99% of the time with ecs is tensioner alignment
Old May 1, 2022 | 12:14 PM
russ472's Avatar
russ472
there are numerous threads on this page with people that have had this issue. can't remember reading one that the tensioner alignment was the issue.
Old May 1, 2022 | 09:14 PM
Mizfitcreations2.0's Avatar
Mizfitcreations2.0
Mine was jumping and 100% was the tensioner alignment pushing it. Laser aligned and adjusted and no issues after.
Op, you adjust the nut in the middle. I do recommend the laser alignment tool to verify
Old May 2, 2022 | 10:14 AM
helga203's Avatar
helga203
get in touch with ECS. they been on here maney time they are on here helping people with the tensioner anglement.
Old May 2, 2022 | 01:48 PM
romandian's Avatar
romandian
you can do it with straight edges. my blower pulley needed a different spacer. get a flanged blower pulley as well.
To Ecs kit tensioner alignment
