Last year I did some Iron Mask Airflow porting on my heads and Eforce. That along with a 232/248 .626/.626 117lsa +4 cam. We also shaved the heads a little to bump compression. We made 801/800 to the tires on a Dynojet dyno. A couple weeks ago the bottom end let go.
So the new plan is a Texas Speed 416 short block, PRC heads, Johnson link bars, and a little bigger cam, not sure on specs yet. We're going to do 11.5:1 compression and maybe shoot for less boost and then spray it a little when I'm at the track or after I get the car moving a little. On the street it was pretty hard to use the power/torque that I was making before.
I wasn't logging when it happened so I don't have that, but I heard felt a little something but before I could lift it cam apart. Pulled the blower and passenger head the #6 piston is gone and broke the #5 rod.
thats amazing power on this setup, i have an eforce on my Z for several years with no complaints. all stock. nice to see it make those numbers. very cool
