C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Best cam choice
Old Jul 29, 2023 | 12:08 AM
Acloutsuki's Avatar
Acloutsuki
Default Best cam choice
Have an ls3 with A&A supercharger v3ti, headers, and e85 with the 6l80 with a 3600-3800 circle d triple disc. Made 635whp reving up to 6200-6300 with a 3.4 pulley
looking to get the most I can get out of a cam. Willing to sacrifice drivability to get the most. Would also prefer a nice loud chop if possible. I dig race every once in a while but mostly do roll racing. What would be the best cam to go with? So far I’ve talked to BTR and they recommended their fairly new red hot cam. I also talked to GPI and they recommend their ss3. Can’t find much on either of them which a supercharger setup. Which one would be better out of the 2 and why? Is there better options other than those? What do you guys recommend or have and how do you like it.
Old Jul 29, 2023 | 08:29 AM
Spaceme1117's Avatar
Spaceme1117
https://cammotion.com/camshafts/cs-2...r-centrifugal/
Old Jul 29, 2023 | 12:49 PM
Acloutsuki's Avatar
Acloutsuki
Bump
Old Jul 29, 2023 | 09:24 PM
Petera90's Avatar
Petera90
How do you want the car to drive?
Old Jul 31, 2023 | 12:15 PM
PSSSSSHC6's Avatar
PSSSSSHC6
Your limits will be the blower and over spinning. So keep that in mind when selecting a cam vs rpm vs impeller speed. A big cam will want to turn rpm which will make you go to a larger pulley to slow the blower down so you can rev it without tearing up the unit.. You will suffer everywhere to get some rpm.
I would recommend a cam that peaks 6200-6400rpm and pulley that unit to 3.47/10%. Then shift at 6500rpm. That will **** that blower off making mad low-mid range. That unit really isn't setup to turn rpm and stay alive.
Old Jul 31, 2023 | 11:03 PM
Petera90's Avatar
Petera90
his limit will be the fuel system. N/a cams are amazing for centri kits blowers. The tight LSA will keep the low rpm snappy. While the centri does work at the top. Personally, 3.4 pulley and only making 635 tells me your belt is slipping. Pulley up to a 3.8. Add a n/a cam and you need a meth system. Guaranteed over 700 wheel with blower not even breaking a sweat
Old Aug 1, 2023 | 01:37 AM
Kingtal0n's Avatar
Kingtal0n
The blower limits power, not the cam. Increasing lift will reduce reliability and stability and longevity of the valve train. Increasing the duration of the cam will decrease low rpm torque and make the car feel slower at low rpm without a properly setup converter/gear/tire. It will also make the engine breath more at top RPM forcing you to rev the engine higher and causing boost to drop given the same blower drive rate, which is not necessarily a good thing for a centrifugal compressor wheel which generally flow more and have wider efficiency window at higher pressure ratios.
Don't get me wrong, I always put an aftermarket cam in my engines for reasons. But I do it myself and I've been doing it for 27 years, and those reasons are not for power purposes or making the vehicle faster. Its more for linearity of torque curve and tuning reasons (it makes the VE table flatter and limits low rpm cylinder pressure which helps with reliability on gasoline which is important if you are using cheap gasoline fuels) plus I like how they sound and feel. But the power comes from the compressor wheel; if the compressor runs out of power, the cam isn't going to add not even 1hp. Cam a modification that will risk opening the engine to debris, spun cam bearings, dirty technicians hands, improper torque sequences, leaking gaskets, etc... for no real performance gain in the world of small-ish blowers on street vehicles.
If the engine has the spring for it, I tentatively recommend pulley up to the blowers or engines maximum HP and keep the current camshaft, it will make the same power as any other cam, with more economy, more reliability, more longevity, lower rpm, reduced wear and tear, less risk, less combo matching necessary modifications.
Old Aug 1, 2023 | 10:54 AM
PSSSSSHC6's Avatar
PSSSSSHC6
If we are breaking things down there are other weak points that can be found when looking for more power. Any cam will make power with boost but the Centri unit will not keep making power and turning rpm just because its a Centri. Its all based on pulley combo and impeller speed. Tons of people run massive cams and can't pulley down on the blower anymore because they will over spinning it. That shortens the self contains life span and drives the IATS through the roof. The V3 is not a top end unit. Its internal step up gearing is setup for low-mid range not top end. The V1 on the other hand would work better for mid-top end due to the step up gearing and it can handle getting over spun because its an oil feed HD unit.
Can't based what he did on the dyno from anything because it could be a greedy dyno. Everything could be 100% fine.
Old Aug 1, 2023 | 09:30 PM
Petera90's Avatar
Petera90
Op,
if you want a cam that sounds nice, drives nice, and makes more power than stock. Pat G recommend this cam too me.
224/232 .604/.598 114+4
Old Oct 13, 2023 | 12:47 PM
LS YEET's Avatar
LS YEET
ECS novi 1500, Nightfury cam, full exhaust 640rwhp with restrictor plate on 93. Drivability is great, nice sound and decent power.
Tried to add a video but all my videos it says the files are too large for the forum.
Old Oct 15, 2023 | 01:31 PM
tektrans's Avatar
tektrans
manual or auto?
Old Oct 15, 2023 | 01:56 PM
LS YEET's Avatar
LS YEET
Originally Posted by tektrans
manual or auto?
manual
To Best cam choice
