C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
What window switch
Old Oct 18, 2023 | 08:54 AM
Smokehouse00's Avatar
Smokehouse00
Default What window switch
What window switch are people using for nitrous on a ls3 car. The nitrous outlet winmax is on sale right now. But I don't know if it would work on coil on plugs
Old Oct 20, 2023 | 06:07 PM
camaro75racer's Avatar
camaro75racer
I used a maximizer 5 when I had the spray and it was perfect.
Old Oct 24, 2023 | 10:15 AM
da6speed's Avatar
da6speed
Years ago, I used the Nos Mini Controller and it had a window switch built in.
Old Oct 24, 2023 | 10:37 AM
m60gov20's Avatar
m60gov20
I run the Nitrous Outlet Winmax switch on mine with coil on plug. It's a great easy to use switch.
Old Oct 24, 2023 | 12:28 PM
Smokehouse00
This is the one I ended up getting. Where did you get the tach signal from ?
Old Oct 24, 2023 | 12:52 PM
m60gov20's Avatar
m60gov20
My tuner recommended grabbing everything at the ecm everything you need is right there with power and ground close by too. Let me know if you need a pin out I can get one for you. I had already grabbed my pedal signal at the the pedal before he recommended that so I went ahead and grabbed the tack at the back of the cluster.
Old Oct 24, 2023 | 01:29 PM
Smokehouse00
Yes the pin out would help a lot. Did you have to remove the fender to get to the ecm
Old Oct 24, 2023 | 07:51 PM
m60gov20's Avatar
m60gov20
What year is your car?
Old Oct 24, 2023 | 07:53 PM
m60gov20's Avatar
m60gov20
You can just take the right front wheel and liner out and access it.
Old Oct 24, 2023 | 08:04 PM
Smokehouse00
Old Nov 13, 2024 | 09:58 PM
C6 badass's Avatar
C6 badass
1st Gear
Default Tach wire
what pin on ecm for tach signal
To What window switch
