Advice Appreciated
1.) Heads-I am attaching the current heads as this was a N/A build. I am going with PRC 285's as he wanted to get the compression down just a bit as the FED heads are heavily milled. So, -5CC piston now instead of -20 wiseco forged. Compression will sit at 10:7:1. Any one with experience on how these heads will run with V3 TI and getting a 6 rib 3.47" pulley?
2.) This car has ZR-1 rims. Michelin run flats (I despise them and a culprit) 335/25zr20 in rear. 285/30zr19 in front. I can't find a replacement outside of more run flats. I assume I will have to change rim size? I know I will in the rear for any traction, so a 17" drag radial? I have 19" MT drag radials for the rear of my CTSV-maybe they would work as I will have to look at the lug pattern? I put new Toyo tires on CTSV and they spin like hell from a roll, so not impressed with them, but seem to work for many
3.) Ride-Outside of tires the car looks to have been lowered. Any suspension parts that would help smooth it out a bit?
4.) Trans (6060) shifts fine. Can't get it in reverse after it warms up and I think that's a cable issue. It makes a "tree leaf in the HVAC fan noise" when in 2nd or third. Not bad, but anyone? 1st, 4th on and no noise. The noise is very low and have to listen for it
5.) Heat in center, as I know that's normal, but do they make any material to install to reduce?
6.) Any tips on a better ride would be appreciated and I know this is limited info somewhat.
I must really like this car and spending money on it...
2.) This car has ZR-1 rims. Michelin run flats (I despise them and a culprit) 335/25zr20 in rear. 285/30zr19 in rear. I can't find a replacement outside of more run flats. I assume I will have to change rim size? I know I will in the rear for any traction, so a 17" drag radial? I have 19" MT drag radials for the rear of my CTSV-maybe they would work as I will have to look at the lug pattern? I put new Toyo tires on CTSV and they spin like hell from a roll, so not impressed with them, but seem to work for many
2) 17'' wheel and 26'' tire below 800whp, 28'' tire up 800whp
3)You can raise the car with factory leaf spring bolt. https://www.corvetteforum.com/articl...ette-for-free/
4) You dont have cable but a shifter rod. First thing to do is remove the center console and check for proper aligment and if your shifter rod bolt is not loose C5 show in video but same thing on C6
6)Its nearly 20 years old car, new shock and aarm bushing help a lot.
4) You dont have cable but a shifter rod. First thing to do is remove the center console and check for proper aligment and if your shifter rod bolt is not loose C5 show in video but same thing on C6 https://www.youtube.com/watch?v=wfsWH_VZv60
5)https://rpmoutlet.com/product/design...-complete-kit/
You can tighten and secure that bolt and solve your problem, usually for a while but the second issue is that the box portion of your shifter is worn out. Not just yours, they pretty much all are. If you upgrade your box it will eliminate a lot of rattle, slop and vagueness in the shifter. The box is responsible for most of the slop, vibration, rattle, etc. and the shifter not so much.
If you want to address the box I have two different options, fell free to shoot me an email or PM if you have any questions, I'm happy to answer anything I can, this is an easy one and you'll like the way the shifter feels much better afterwards. I hope this helps check one issue off the list.
Here are a couple pics of the box that lives below the shifter and the shaft that connects the (stainless steel) shaft from the box to the linkage.
Linkage with clamp and bolt that likes to loosen up.
Shaft from box fits into linkage, secured with clamp.
Upgraded box.
Shaft from box shown without clamp.
Shaft slippage.
Upgraded box.
Shaft slippage.
