C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
A&A bracket questions
Old Jan 11, 2026 | 10:41 AM
SteveJewels's Avatar
SteveJewels
Default A&A bracket questions
Can the A&A bracket be properly installed with a direct fit Mezerie electric water pump. What about an Edelbrock 8894 which is supposed to be a form, fit, and function replacement.
Can the A&A bracket be properly installed with a water manifold or just adaptors to run a remote electric water pump?
I am having a new engine built with DART Pro1 LS heads. Can the A&A bracket be properly installed with these heads?
The bracket I have now was installed around 2012.
Thanks!
Old Jan 11, 2026 | 08:22 PM
SteveJewels
Can a pump manifold be bored and tapped for support holes for the A&A bracket?
Old Jan 16, 2026 | 12:23 PM
playtoy's Avatar
playtoy
Quick answer is yes but it will require some modifications
Old Jan 18, 2026 | 02:51 PM
SteveJewels
Thanks!
The guy doing the install is pretty good. His main business is LS swaps so he is used to fabricating and finagling.
To A&A bracket questions
