Vacuum block placement
1. Tap the map port to connect the catch can by itself. And T off the brake booster line for the vacuum manifold for all the other things including the map sensor via remote mount. Can the brake booster line hold that much things coming off of it? Or would it affect the vacuum going to the brake booster and decrease its effectiveness?
2. Tap the map port for a dedicated line for the vacuum manifold. Put a T on the intake manifold for the brake booster and the catch can. Im not sure if the catch can can be connected to the same spot as the brake booster or if the catch can needs its own port by itself.
3. Tap the map port for the catch can, leave the brake booster alone, and drill and tap a new hole for the vacuum manifold alone. This being the ideal option but not sure if drilling another hole would be possible.
Anyone have any advice?
I welded a bung on the lid on my low ram and ran that to a vacuum block into the cowl. Not the "cleanist" option but it works. It's tight in the back since the low ram obviously sits lower than a hi ram. You would have to cut more out of the cowl to fit extra fittings. Where I welded the bung on the lid, it clears the hood.
