while you could program the stock ecm to never to into closed loop, I don't think there is a way to calibrate it to read a wide-band O2 sensor. Plus, in open-loop, it always trys to achieve the same afr, usually 14.7:1. Unless you want the car to run rich ALL of the time, you would not be able to program both part-throttle and full throttle to run safely without using open loop
What I was hoping was that running WBO2s would allow closed loop all the time, which might simplify the tuning particularly at WOT. For example, program the PCM to run 12.5 AFR at WOT and 14.7 at cruise.
Anyhow, this approach doesn't seem feasible & a normal dyno tune is not all that expensive.
Yeah, you can run this method, however it's called an Open loop speed density tune. You tune the car based on wideband readings only. Tune for 14.7 everywhere and tune WOT to your desired afr.
I run this OLSD(open loop speed density) method on my GTO.
What would be the purpose to run closed loop with widebands?
same purpose as running closed loop with narrowbands, except that now you always get to know how off you are, not just when you're commanding stoich AFR.
i just wrote up two articles differentiating SDvsMAF and OLvsCL, cause i've seen too much confusion about it on the forums, so this thread is perfect for plugging these:
Once we have AutoTune, you'll effectively be able to run closed loop off of the wideband. Instead of just updating trims, it will be updating the VE table directly.
(Wait, I'm not sure if RTT will be available on LS2s.)
It is my understanding that the 07 ecm doesn't use VE tables as such but a rather complicated mathimatical formula to constantly calc and update afr. Is this correct???
GM for many years now has used a method called DYNAIR (Dynamic air flow)
It involves using predicted air charge (PV=NrT) and Measured air (MAF) So if the engine controller has a MAP and a MAF then it is using both, (DYNAIR) if there is no MAP then it is using measured air, (MAF) and if there is no MAF then it is using Speed Density.
If you have a desired AF then all you need to know is how many grams of air are entering the cylinder and the how many grams of fuel the injector can flow. Mapping this out for the entire load range the engine will be operated in is called tuning. If you have your math right then there will be little error in the AF, this is where the narrow band sensor is used to correct for this error which should be within 5% in all cells where STOICH is desired.
If you have any further questions please let me know.
