C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
speedometer question
Old Jan 25, 2007 | 09:51 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
Default speedometer question
it is my understanding the the speedometers (two if you've got the hud) use an electrical connection from the top of the diff. to determine and display the speed of the vehicle.
back in the old mechanical days one could swap out the 'speedo' gear in the side of the tranny to adjust the speedo as needed.
is there any similiar adjustment one could make to the c6 ?
Old Jan 25, 2007 | 11:03 AM
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
It is adjusted automatically by the ECM. I switched to 4.10 gears and didnt have to adjust anything. Chuck from Corvettes of Westchester explained how it works to me exactly, but I couldnt repeat it.
Old Jan 25, 2007 | 02:53 PM
suprkik's Avatar
suprkik
the vehicle spped sensor isnt in the tranny on these cars it actually reads off the ring gear itself , when you change gears the new gears already read correctly. If you have a manual your ok , auto though sometimesneed shift points altered a little.
Old Jan 25, 2007 | 03:08 PM
Zig's Avatar
Zig
other than being in metric mode, what would cause the speed displayed to be inaccurate ?
Old Feb 5, 2007 | 07:14 AM
EC_Tune's Avatar
EC_Tune
With a manual you don't need a speedo recalibration. Same with the Auto.
EXCEPT: your shift points will be way off with the auto. You will have to recalibrate to make the transmission shift correctly again.
EC
HP Tuners Beta Tester
Old Feb 5, 2007 | 07:21 AM
Zig's Avatar
Zig
re: recalibration.
how would one uncalibrate ?
To speedometer question
