C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Hacking the system
Old Apr 11, 2007 | 05:53 AM
BLATZ's Avatar
BLATZ
6th Gear
Default Hacking the system
Does anyone know of a way to get rid of the Covette msg that shows up when you start the car?
When one erases the flash memory, will the car stop working?
Two of the many mysteries of car electronics. This is my quest.
Old Apr 11, 2007 | 08:39 AM
6Speeder's Avatar
6Speeder
If you are talking about the message on the DIC, then check your manual. I believe that is programmable, you can make it say whatever you want.
Old Apr 14, 2007 | 11:15 AM
ROD BROWN's Avatar
ROD BROWN
Default Changing the message
Refer to the Manual. I personlized the greeting message.You are limited to a certain amount of letters.You cannot remove the Chevrolet greeting.I have the personal greeting," custom made for Rod Brown".
To Hacking the system
