C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Car throwing P0641 code - interpretation???
Old Jun 25, 2007 | 12:49 PM
ourayzman's Avatar
ourayzman
Default Car throwing P0641 code - interpretation???
My car went into reduced engine power mode recently so I pulled codes and it had one, P0641. My code reader interpretted it as
"Sensor A reference Voltage Circuit/Open". Another list of codes indicates it means "5-Volt Reference 1 Circuit ECM". Does anyone know which sensor A is? or have any further information on this code.
Thanks in advance
Old Jun 26, 2007 | 07:49 AM
REVAK's Avatar
REVAK
Thanks in advance
You may want to see your dealer for this one. DTC PO641 pertains to 6 sensors bussed together in the ECM. MAP, EOP, FTP, A/C, APP, CMP.[manifold absolute pressure,engine oil pressure,fuel tank pressure,air conditioning refrigerant pressure,accelerator pedal position sensor#2,camshaft position sensor, 2006 . Check for a loose gas cap first.
Old Jan 26, 2009 | 07:56 PM
Luweegy's Avatar
Luweegy
I would ck wiring at the sensors mentioned.
To Car throwing P0641 code - interpretation???
