I have a 07 C6 and just had LG Longtubes, free flow cats, x-pipe and Corsa Extreme cat-back added with 160 stat. The fan runs all the time, even when the car is just started.
At what coolant temp should my fan turn on and off?
Your exhaust work shouldn't affect where you set the fan. I have mine set to come on sooner, at higher percentages. 192:20% 194:50% 196:70% 198 and above:89%
I set mine with the Predator to effectively double the % from 203 to 221, then come on at 99%. If it gets to 220, I want full power to the fans. But I agree with 6Speeder that exhausts should have nothing to do with fans running.
