07 C6 A6 Supercharger?
If I installed a Supercharger on an 07 A6 is the auto transmission able to be tuned yet? And if it can't be tuned ie., shift points etc., will the lack of trans. tune hurt it?
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,090 Likes
Not all tables are availible yet, but you are covered to install a SC. We have several 5-600 rwhp A6's on the street. Good luck with your build.
If you mean performance hurts: It really hurts 60 foot times. 60 foot times are the same as before the SC install (1.9). WOT shifts are just terrible. Engine revs up between shifts and the next gear slowly slides in.
If you mean breakage hurts: I doubt it. That's what all the TM crap is about.
You can adjust the shift points (and raise the rev limiter slightly to give the trans more time to shift)with HP Tuners. I'm in the process of having that done now...........and you WILL want to. The trans cannot shift fast enough (with the factory settings) if you put some serious hp in front of it.
