Predator promises??
I asked the above question shortly after purchasing the Predator and was told the capability would be available in a "few weeks". The next two times I asked the question I received the same answer. The last Time I asked the question (8/10/07), Mike replied "about a month".
I am beginning to wonder it Diablo is even working on the problem. They sure are active in other areas (Ford and Chrysler). They seem to have forgotten about the Corvette.
I don't know about the rest of you, but I am losing patience! We paid for something that we have not received.
In fact, the lack of TCM support extends all the way to 05-06 GTO, the LS4 applications, and 07 NBS trucks.
This is being worked on, and has been for some time. Unfortunately, as with any electrical/engineering job, there have been unforeseen delays.
I have asked several times recently for an ETA on the availability of TCM support, but have not been able to get anything exact. I am hearing that it may still be a while, likely around the first of the year.
Rest assured that while we have been releasing some new Ford and Chrysler stuff, we are still hard at work on our GM applications as well.
As we speak our engineers are cranking out a new revision for the U7194 to allow it to support the 08 GM trucks, and after that we will be doing 08 Vette and the new LMM diesels.
Mike
Mike
1. The competition solved the problem.
2. Tuners have solved the problem.
3. Perhaps they should complete and deliver the features to current customers first.
Reading between the lines, your reply implies that the A6 is not very high on the priority list. It is hard to believe that based on Diablo's past performance, if solving the A6 problem was important to Diablo, it would have been solved. The missing ingredient is effort.
Steve H
Steve H
I don't know why anyone wastes their money on those crummy tuners anyway. Go to a "real" tuner and put your car on a dyno and get it tuned and setup right.
Steve H
The TCM project we are on right now, once complete will add TCM support to everything not currently supported....from a 4L60E to your 6L80E.
Mike
Mike
PS - yes I have inquired with several tuners here about getting a TCM tune from them because of the delay from Diablo. Even if I go down that road, I will continue to tweak and learn. Like I said, I may purchase my own tuning gear. I think Jeremy could use the competition ... lol ... just kidding.
Kooks long tubes, XO and hi-flow cats
Corsa sports
Vararam with TB spacer
Ported intake
160 thermostat
A few more planned
I bought the Predator (model-slp7190) to modify the tune accordingly.
-First the unit wouldn't boot and I had to talk with tech support to upload the CROM file.
-Now the unit boots up properly but when connected to the OBD-II port and going to "Performance Tune" it displays; "12605740 - part number not found in vehicle database".
-spoke to Diablo Tech and was told I had an unsupported earlier version factory program and would have to have the dealer reflash to the latest revision
-took the car to the dealer today (used the battery run-down complaint) and had the reflash done.
-just connected the predator and got the same message.
-I've already requested an RMA to send this "tool" back, but was hoping to give it another try.
-after reading this thread I'm not so sure I should...
Has anyone had a similar experience or have any suggestions....
The car only has 11,600 miles on it, and still has 9 months left on the factory warranty.
I've already raised the dealer's curiosity and not sure I want to be going in a second time unless I have some solid info and confidence this tool is worth the effort.
Bottom line - something is wrong with your unit, send it back. Sorry.
Bottom line....IMO - The Diablo specs say the unit it supposed to work with a factory tuned 2005 C6. If there is a gap in their firmware that doesn't allow it to work with my particular factory version, Diablo needs to correct it....
I (and no one else for that matter) should have to be negotiating with a dealer, raising questions, and creating potential warranty issues because Diablo hasn't done their homework and addressed early versions of the C6 firmware.
Hopefully, we'll be able to work through this. I've heard a lot of good things about Diablo and would like to take advantage of the flexibility this tool offers.
The ball is in Diablo's court....we'll see what happens.....
Thanks again......
We have been selling Predators a long time, and have not ever had a "defective unit". If it turns on, and communicates with your car it is working. Also, the software is pretty static also...and since you downloaded the new firmware that works for everyone else..but not on your car...then something is up with the car. The closest we have come to having a defective unit is when they come from the factory without a CROM file. This is fixed easily by downloading the newest crom file from Diablo's site..which you should do anyway.
Just some food for thought...
Every Predator we have ever had a user claim was defective..we have brought back in, reflashed with the newest software, and tested on one of our cars...and they work fine. We have resold them as open box with no issues or complaints from the next owners. So..while it is easy to blame the unit...more than not, it is user error or some kind of software gremlin with the car.
Not saying that is the case here...however you have to use past experiance to guide in fixing new issues. Additionally, while Diablo provides support for this tuner, it is an SLP product meaning they would have to authorize a warranty return. I will contact Mike on Monday and get him on it. If he cannot get it squared away, we will bring SLP in the loop.
