C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Predator Help
Old Jan 27, 2008 | 09:48 PM
racruzzz's Avatar
racruzzz
Default Predator Help
I have been doing some logging with my Predator and noticed my A/F was running rich 10.8 to 11.0 at WOT I wanted to lean it out a little but when I tryed to edit the tune i was given a message " Motor and trans type not supported" The Predator im using is a VR7194 with the
8r04 crom I have tryed to upload the new 8r10 crom. Predator message " cannot load u7194
application into vr7194" and now the unit will not boot Message says "Requires crom file before use". Anyone have an idea.
Old Jan 28, 2008 | 10:45 AM
Mike L.'s Avatar
Mike L.
Are you running a supercharged setup?
The Predator you have is for a Vortech supercharger kit.
You are attempting to apply the wrong .crom file update to it.
I'll see if I can find the correct crom file for this tool.
Mike
Old Jan 28, 2008 | 01:04 PM
racruzzz's Avatar
racruzzz
Mike,
Yes the car is supercharged. I just talked to Christina and she send me crom 8r05 which is the update for my unit. Do you know if the tune in the VR7194 is locked i cant modify the parameters, or did this get addressed in the new update?
Old Jan 28, 2008 | 01:51 PM
Mike L.'s Avatar
Mike L.
Mike,
Not sure if you can actually modify any of the parameters in this tool, as Vortech may not want to let you mess things up...
Mike
Old Jan 28, 2008 | 10:14 PM
racruzzz's Avatar
racruzzz
Mike,
I loaded the 8r05 crom now the unit boots just fine. When i try to go to the performance tunes I get an error message saying vehicle not supported I have a 2007 Corvette with the 6 speed auto
Old Jan 29, 2008 | 11:16 AM
Mike L.'s Avatar
Mike L.
Mike,
Sure you had the car in the accessory position?
Try again, and try going through the menu and keep trying, as I have seen these tools do some strange things like that before.
You did restore the stock tune to the car before you updated it, correct?
Mike
Old Jan 29, 2008 | 01:41 PM
racruzzz's Avatar
racruzzz
Mike,
No I did not restore the stock tune. Should I reload the factory tune
then try and reload the Vortech tune?
Old Jan 29, 2008 | 01:48 PM
Mike L.'s Avatar
Mike L.
Yes, you must ALWAYS restore the backup before updating the Predator.
To Predator Help
