C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Disable traction control?
Old Jan 30, 2008 | 10:17 PM
Hooked4Life's Avatar
Hooked4Life
Default Disable traction control?
At the track I always forget to turn off TC. Is their an easy way to do this in the tune so I don't have to keep turning it off at every start? I want to keep AH on.
Old Jan 31, 2008 | 07:38 AM
Ted P's Avatar
Ted P
just push the button to turn it off. No tuning that I'm aware of and why would you want to turn it off permanently for everyday driving?
Old Jan 31, 2008 | 09:36 PM
Hooked4Life
Not for every day, this would be a track day only tune. I think I figured it out anyway, thanks.
Old Jan 31, 2008 | 11:24 PM
C5pilot's Avatar
C5pilot
A checklist taped to the dash works too.
However, there are TC settings in HPtuners but I haven't tested them out yet.
Old Feb 1, 2008 | 10:14 PM
siffert's Avatar
siffert
No, nothing in HP Tuner like that to turn off TC for you. There is a difference between traction control and torque managment. Its really not hard to have a mental checklist before swinging into the staging lane to turn off TC, and for me, making sure I am in "S" mode and start HP scanning mode.
Old Feb 1, 2008 | 10:52 PM
BAADC6's Avatar
BAADC6
Old Feb 2, 2008 | 05:15 PM
QU1NT's Avatar
QU1NT
Man how much more easy do you want than to simply push a button?
You could always get a trunk monkey. He could jump out of your trunk and push the button for you. As a bonus he would privide security for your vette when you're not around
Click to see trunk monkey "theft prevention" in action.
Old Feb 3, 2008 | 11:06 PM
Hooked4Life
I just set the TCS enable temp to 300, and it appears to work fine. I can do a smokey burnout without the assistance of the trunk monkey.
Old Feb 3, 2008 | 11:40 PM
siffert's Avatar
siffert
Not sure that your TCS enable temp 300 is that smart of an idea. Since you are so forgetful as you say, no doubt you will forget to set it back to -40 degrees after your smokey burnouts on the track. You'll then find yourself flooring the car one day where you should not be, and the next thing you'll find yourself and your C6 spinning and sliding off the road, or into another car, or even a shop window.
Old Feb 4, 2008 | 09:35 PM
Hooked4Life
I got the trunk monkey to help me with that. My track tune is for the track only.
Old Feb 4, 2008 | 09:54 PM
siffert's Avatar
siffert
I see. OK. Not having a memory problem, my street and track tune is the same for me. Wherever I am, its always the fastest time between point A and B.
Old Feb 5, 2008 | 02:24 AM
QU1NT's Avatar
QU1NT
Hahaha
Hey if you ever have any problems with an aggressive driver, the Trunk Monkey can help with that too
To Disable traction control?
