C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Predator idle adj question
Old Mar 2, 2008 | 09:36 AM
REVAK's Avatar
REVAK
Default Predator idle adj question
Using the predator on my 06, I found I can raise the idle above the stock setting of 650 rpm, but it will not lower the idle setting below 650 rpm , any thoughts on this ? thanks in advance.......
Old Mar 4, 2008 | 01:21 PM
06MonteSS's Avatar
06MonteSS
Supporting Vendor
the PCM does not/will not support a lower than stock Idle speed setting, so that adjustment is not possible....
Old Mar 4, 2008 | 02:56 PM
REVAK's Avatar
REVAK
Default Idle adj.
Thanks, good to know, now at least I can stop screwing with it !
To Predator idle adj question
