C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Please help!!
Old May 25, 2008 | 03:59 PM
Andrew-NY's Avatar
Andrew-NY
Default Please help!!
My pcm is locked with LS2 Edit. My car is a 2005 C6.
Thank you
Old May 25, 2008 | 04:55 PM
Braciole's Avatar
Braciole
St. Jude Donor '08
Thats what it sounds like to me they locked it. I would call them and explain to them what you did. You shouldnt have had a slow down??
usually just a pick me up when you get it retuned.
Mike
Old May 25, 2008 | 05:15 PM
Andrew-NY's Avatar
Andrew-NY
I know for a fact it's locked.
Old May 29, 2008 | 04:43 PM
Fasterproms's Avatar
0Fasterproms
Former Vendor
Did you tune the vehicle yourself with your own Edit or did you have someone tune it? If it is an older version of LS2Edit, most likely your only way of having it unlocked is to take the tune out of the vehicle. The newer version of LS2Edit should not lock the PCM's
Shalane F
Old May 30, 2008 | 12:18 AM
Braciole's Avatar
Braciole
St. Jude Donor '08
Do you have an update Andrew?
Mike
Old May 30, 2008 | 10:00 AM
Andrew-NY's Avatar
Andrew-NY
I switched to a new pcm; it was easier to do it this way. Car is 'spin-tuned' now...
To Please help!!
