C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Help Please
Old May 31, 2008 | 12:27 PM
05vettelag's Avatar
05vettelag
Default Help Please
How do i enable these so they show up under trans-torque managment?
Torque Reduction Master Enable: This switch enables or disables trans torque reduction (including abuse mode etc.) (not available in all calibrations)
Torque Reduction Enable Upshift: This switch enables or disables trans torque reduction on upshifts. (not available in all calibrations)
Torque Reduction Enable CT Downshift: This switch enables or disables trans torque reduction on closed throttle downshifts. (not available in all calibrations)
Torque Reduction Enable Power Downshift: This switch enables or disables trans torque reduction on power downshifts. (not available in all calibrations)
Torque Reduction Enable Garage Shift: This switch enables or disables trans torque reduction on garage shifts. (not available in all calibrations)
Shift Torque Reduction Enable: This switch enables or disables trans torque reduction during shifts (not available in all calibrations)
Old May 31, 2008 | 12:28 PM
05vettelag's Avatar
05vettelag
mine only has these 3.
Torque Reduction vs Torque vs Shift - Normal: This table defined percentage torque reduction during shifts in normal mode
Torque Reduction vs Torque vs Shift - Performance: This table defined percentage torque reduction during shifts in performance mode
Torque Reduction vs Torque vs Shift - Downshift: This table defined percentage torque reduction during downshifts
Old May 31, 2008 | 03:55 PM
05vettelag's Avatar
05vettelag
hpt said on the 05 that only the 3 will show up its not programmed that way on 05's. also for people who have just tuned out Torque Managment only did you think it feels like it is when the TC is off. Feels like you have to push the peadle a little harder to get the same feeling as with TC on?
To Help Please
