C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Cags
Old Jun 6, 2008 | 09:32 AM
Braciole's Avatar
Braciole
St. Jude Donor '08
Default Cags
M6 C.A.G.S. (Computer Aided Gear Selection aka Skip Shift)
The parameters control the Computer Aided Gear Selection (CAGS or “Skip Shift”) feature of the VCM. It activates a solenoid in the transmission to force shifting to 4th gear under light throttle conditions. If disable TPS is exceeded then the solenoid will not activate.
  • Disable %TPS: Throttle Position to disable C.A.G.S. routine
  • Enable Speed: Speed to enable C.A.G.S. routine
  • Disable Speed: Speed to disable C.A.G.S. routine
  • Enable Baro: Baro to enable C.A.G.S. routine
  • Disable Baro: Baro to disable C.A.G.S. routine
  • Min Coolant Temp: Minimum Engine Coolant Temp required for C.A.G.S. routine
Which one do I use to diable the cags???
Disable Speed??
or Disable Baro??
Mike
Old Jun 6, 2008 | 03:48 PM
8850's Avatar
8850
Set your file up like this and no more CAGS...
Old Jun 6, 2008 | 05:22 PM
Braciole's Avatar
Braciole
St. Jude Donor '08
Mike
To Cags
