C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
problem with predator
Old Oct 11, 2008 | 04:57 PM
rothchilds's Avatar
rothchilds
Default problem with predator
Ok, so I have experienced this before, and now it is back. My predator wont read the p/n file when I try to load a tune. I looked at diablo's forum, and they said that it is usually associated with the device not seeing the key as on, or acc mode for our cars.
Does anyone have a fix for this? Last time I was able to get it to work by cycling the start button between off and acc mode, and finally it worked. But I have tried that 10 times now and it wont read the file. The radio and the onstar fuses are pulled, I have used a predator many times, but for the last 2 times I keep getting this error.
Old Oct 11, 2008 | 08:18 PM
HawaiiC6's Avatar
HawaiiC6
Sounds like you have a defective unit, did you post on the predator forum?
Sorry wish I could help but my predator has never given me any problems.
Old Oct 11, 2008 | 08:59 PM
danl72's Avatar
danl72
You should contact them.
To problem with predator
