C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
check engine light
Old Oct 14, 2008 | 06:20 AM
R50THC5's Avatar
R50THC5
Default check engine light
I had my check engine light come on for the second time in about 5 weeks and this occured after a WOT burst. It codes out as too lean stage 1&4 after the first time it said 1,2, 3 if I remember correctly, what ever that means. Procharger has been flawless since Aug 2007 install (nearly 10k miles). Has anyone else had this experience and what was your resolution. My tune is EFI live.
Old Oct 29, 2008 | 05:33 PM
shifter77's Avatar
shifter77
YOUR OXYGEN SENSORS IN THE EXHAUST MUST HAVE GONE BAD
Old Oct 31, 2008 | 02:18 AM
Shortimer's Avatar
Shortimer
That would be my first guess as well. O2 sensors are a major factor with CEL problems. Best of luck clearing it up.
Old Oct 31, 2008 | 11:09 AM
not08crmanymore's Avatar
not08crmanymore
Black smoke out the back and running rough is a dead giveaway for the 02's.
To check engine light
