C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Predator Experts please step inside.
Old Dec 9, 2008 | 01:13 AM
bent's Avatar
bent
Default Predator Experts please step inside.
I am having trouble with the TM reduction aspect of my SLP7194. Those who are famillar with the 7194 have said that "the torque management is removed in the tunes, from the engine side of things"
and I believe that is true and what is to be expected. However I don't feel that mine is doing this. Here is the short reason why....I used the real time data function and logged a wot pass which included 1-2 shift, 2-3 shift, and 3-4 shift. The parameters I monitored were spark advance, engine speed, AFR, torque management spark retard, knock retard and total knock spark retard. At EVERY shift the value for the torque management spark retard spiked and the timing dropped from 27 degrees to negative 12 of course, after the shift is complete, the timing returns to "normal" untill the next shift. This tells me that TM has not been turned off or even reduced. I am not showing any knock retard at all and the total knock retard spiked at launch but stayed at zereo for the rest of the pass.
Are my deductions wrong? this is new to me but I do have plenty of general automotive experience and it seems like things just aren't adding up. What do ya'll think? :
Old Dec 9, 2008 | 08:24 AM
06MonteSS's Avatar
06MonteSS
Supporting Vendor
http://diablosport.com/index.php?nam...wtopic&t=11675
Old Jan 24, 2009 | 11:46 AM
seevi's Avatar
seevi
I had my c6 tuned locally and have experienced some of the same issues. 1st, I was encouraged not to mess with TM. Reason - transmission life. 2nd, check your AAT and IAT readings. I understand that the ECU will back out a lot of timing when the IAT is above 96 degrees. 3rd - fuel. Using 100 octane racing fuel seems to stabilize the timing issue. Not as much timing is backed out at the shift.
Old Jan 24, 2009 | 01:13 PM
bent's Avatar
bent
thanks for that info!
To Predator Experts please step inside.
