C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Need to clear Diag Code
Old Feb 7, 2009 | 12:28 PM
sditch's Avatar
sditch
Default Need to clear Diag Code
Hello,
I have a issue with the check engine light one and the diage code is Bank A and B are running lean. I tried to use my Diablo tunner to clear the code but it seems not to be working right even after reading the directions.
I had the car tuned my MTI using LS2 edit back when I got a 402 installed. Any Idea's on how to clear this so I can get my Inspection passed?
Old Feb 7, 2009 | 02:16 PM
REVAK's Avatar
REVAK
If your predator wont clear it , you can disconnect the battery for 5 or 10 min. That should clear the code , however you will need to put some miles on the car after,[ aprox. 200 mi.] or it will test systems not ready at inspection.
Old Feb 7, 2009 | 03:18 PM
sditch's Avatar
sditch
Thanks for the response, I have disconnected the battary but the code keeps coming back within a day. I was going to try and update the Diablo firmware to see if that helps. I also have a friend that has EFI live that he said would reset the codes.
Old Feb 9, 2009 | 05:45 PM
sditch's Avatar
sditch
FYI....
I finalliy got the Diablo to clear the codes by holding the start button for 10 sec. to turn on the Ignition and it cleared the logs and I unpluged the battery to clear the alert. In this case I only put about 3 miles on the to drive it to the shop.
Got the Inspection so just want to pass that around, thanks for help REVAK.
To Need to clear Diag Code
